Where do I start? SACD player
0 Members and 1 Guest are viewing this topic. Read 1292 times.
duff138
« on: 9 Oct 2003, 07:03 pm »
I want to try the format out.  If I purchase the Pioneer's new DV-563A will I be getting a good idea what I can expect from SACD, or do I really need to spend more, like getting the Philips DVD963SA, to get an idea of what the format sounds like?  Where's a real good starting point for under $500?
« Reply #1 on: 9 Oct 2003, 08:54 pm »
If you are only interested in SACD you can stick with the Sony or Phillips.  The music I want is split between DVD-A and SACD so I got the 563.  If you are only going to use it in two channel then the better players may be worth it.
Two things to consider.
1)  How soon and how well a hi rez digital out will fit into your system.
2)  What type of preamp you will use if you will go 5.1.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: Where do I start? SACD player
« Reply #2 on: 10 Oct 2003, 12:19 am »
Quote from: duff138
I've got a DV-563A and it sounds really good. You can't beat it for the $.
duff138
« Reply #3 on: 10 Oct 2003, 01:17 am »
just picked one up at bestbuy, pioneer  DV-563A.  so i'm hoping i'll get an idea of what to expect from sacd.  it's got a 30 day money back gurantee so i figured it could not hurt.  if i like what i hear maybe i'll get the urge to return it and get a better player.
