0 Members and 1 Guest are viewing this topic. Read 32334 times.
I simply don't know if these drivers will have similar break-in swings or not and noted that in my report. I know that my standard drivers had well over 200 hours on them before they acted up and went through a swing that lasted about 20 to 30 hours before settling in again and then were fine after that. I only have about 80 or 90 hours on the alnico drivers so it may be a bit too early to tell. So far so good: they sound wonderful.--Jerome
I don't know about you but for me purity and refinement of tone wins out over deeper bass any day. Personally I would seriously look at the new alnico drivers. But that's me. After speaking with Louis today about his speakers and the alnico drivers I'm looking forward to his future offerings. I'd say that there's a pair of Omegas in my future.
Thankfully I wasn't faced with that choice. It is easy to argue that purity of tone wins out over deeper bass, but it is another thing entirely to experience, say, Beethoven's 5th Symphony or Grieg's Piano Concerto No. 1 with properly extended bottom end. The music is much closer to a live performance with the sub than without. Trust me when I tell you that once you have heard first hand what the DeepHemp does for music, you just won't want to settle for anything less. So if you want my opinion, going with just the alnico drivers and leaving out the DeepHemp is possibly a bigger compromise to the overall sound than buying the standard drivers with the DeepHemp. I'm sure there will be those who disagree, but there it is. Let's not pretend that the standard drivers are bad. There are a lot of folks, myself included, who were very satisfied with their overall performance. But I have a strong preference for the alnico drivers. If it is at all possible to do both the alnicos and the DeepHemp, then by all means I highly recommend that you do both. Talk to Louis about it. If you are planning to budget a main speaker purchase now and then maybe later adding the sub, then definitely get the alnico's now and add the DeepHemp later. But if you're going to adopt that strategy then be sure you follow up and get the sub later. You might think that the alnicos go low enough for you, and perhaps they might. But hearing music with the DeepHemp adds tremendously to the listening experience, it is a musical sub and brings more to the table than merely bottom end thump. Alternatively you can get the standard drivers now with the DeepHemp and upgrade the drivers later to the alnicos. This actually makes less sense to me. The standard drivers can take quite a while to break-in, in my case it was about 350 hours or so. If you were thinking of upgrading relatively soon (within a few months) then it makes much better sense to get the alnico drivers out of the gate and add the sub later.Let me put it another way to put a finer point on the subject....if before the alnico drivers became an option you were planning on buying, say, a pair of MaxHemp speakers and a DeepHemp sub...I don't think the alnico drivers eliminate the need for the sub. I know this stuff costs money. I had to budget my speaker purchase and work with Louis on payment terms. I spent over $11,000 on new gear in the eight months before I even spoke to Louis about speakers for the first time. I earn a good living to be sure, but wads of cash are not exactly falling from a tree in the back yard. I won't fund discretionary purchases like this with plastic. If I don't have the cash on tap then I have to budget for it. I did what I had to do to get it done because I did not want to make any compromises. When the alnicos came along I had nearly three months for my wallet to recover (a tiny bit) from all of my other purchases. I think the alnico drivers are worth every penny of the asking price, and so is everything else I have purchased from Louis.With that said, only you can determine what your priorities are. --Jerome
This has been my problem since acquiring a Red Wine 30.2 a couple of months ago. The sounds are so great, and it's just too easy to search and then order on Amazon.com. Takes just a couple of clicks and there goes the $.
Quote from: Randy on 29 Apr 2008, 12:49 amThis has been my problem since acquiring a Red Wine 30.2 a couple of months ago.The splendid sound of the alnico drivers are merely supplying me with an added motive to buy them.--Jerome
