0 Members and 1 Guest are viewing this topic. Read 47986 times.
Woodsyi,Stayonline also carries the nominally same receptacle the 5262 for a buck less. The difference is that the 5262 uses unplated brass, whereas the 8200 has nickle plated brass. -http://www.stayonline.com/detail.aspx?ID=7088As to whether unplated brass is preferable to nickle plate brass... discuss amongst yourselves. Your second choice is more problematic, unless you're feeding the Felix from a 20amp circuit. The C320 C20 inlet is different from the more typical C320 C14 15amp inlet that mate with most IEC cords and found on most components. Be sure you're getting the right type. I don't see any C14 inlets at stayonline, but most of the distributors carry them from SwitchCraft, Schurter, Bulgin, etc... and more bespoke ones, Furutech, Oyide, Acme, etc... are availtable through more audiophile oriented suppliers.
P.S. if any of you don't have an aversion to changing out the plugs on your fancy power cords, the Neutrik line of powercon connectors work really nicely and they only require a 25mm hole. They are cheaper than IEC plugs and lock in, which is a plus.
Gordy sent me some of those strain reliefs. I haven't tried them yet. I admit that I am not quite sure how they work yet. I haven't toyed around with them. Up till now I had been using the electrical box wire clamps. Not sure what they are officially called. I put the screw down clamping part on the inside.P.S. if any of you don't have an aversion to changing out the plugs on your fancy power cords, the Neutrik line of powercon connectors work really nicely and they only require a 25mm hole. They are cheaper than IEC plugs and lock in, which is a plus.
What were the final quanities for each of the parts?
Quote from: whubbard on 25 Mar 2008, 04:07 amWhat were the final quanities for each of the parts?380 boards1600+ capacitorsjust under 250 CMC's
Appreciate all the very hard work Anand.
