Official Felix board/kit group buy thread
mjosef
Re: Official Felix board/kit group buy thread
« Reply #160 on: 5 Aug 2008, 11:25 pm »
Jim, I have a couple pics in my gallery showing what I did...
http://www.audiocircle.com/index.php?action=gallery;area=browse;album=876&page=3
I used 12 ga. solid core house wire for the rails. My intended use was to fit it behind a duplex outlet mounted in a single gang box with a 1" extension (total depth 3").
kyrill
« Reply #161 on: 12 Aug 2008, 11:16 am »
i have ordered the 3x 8111-RC coils (12 mH, 4A) from JW Miller but it is too "much" for my amps
It constricts dynamics in a sense of less bloom and 3D
So i want to try out the 8118-RC (7.3 mH, 9.3A)  dcr is  32 milli ohms against 110 of the 8111-rc
however i need one to try out 6 at the most. the closest bulk is over 200 pcs. ( Mouser/Digikey)
where can i order such small packets?
Occam
« Reply #162 on: 12 Aug 2008, 11:39 am »
http://www.newark.com/jsp/search/productdetail.jsp?SKU=63K4086&CMP=AFC-QO1721829242
149 in stock.
Although I can't speak to the needs in 240vac countries, I use the larger coils(8119-8121) which wouldn't use the group buy boards and simply use 'dead bug' construction. I use the 8120 on my amps.
For future reference, you might want to scan this thread   'Looking fo a specific component' -
http://www.audiocircle.com/index.php?topic=14139.0
kyrill
« Reply #163 on: 12 Aug 2008, 12:00 pm »
thx Paul
