0 Members and 1 Guest are viewing this topic. Read 33541 times.
I bet my F4's would work nicely with my future dream speaker - the Geddes Abbey. Nice job Tom!Anand.
Quote from: JoshK on 12 Jan 2009, 03:11 amAn aikido preamp would likely work well for driving the F4's, but I'd use a 6SL7 or 12ax7 upfront and keep the cables really short. I have an Aikido but it is single ended and I'd like to run them as balanced mono's. John B sent me a few details on his balanced version but I'm still waiting for more info from him. Unfortunately it needs both +/-300vdc so won't be the easiest to implement.
Quote from: TomS on 12 Jan 2009, 03:34 amQuote from: JoshK on 12 Jan 2009, 03:11 amAn aikido preamp would likely work well for driving the F4's, but I'd use a 6SL7 or 12ax7 upfront and keep the cables really short. I have an Aikido but it is single ended and I'd like to run them as balanced mono's. John B sent me a few details on his balanced version but I'm still waiting for more info from him. Unfortunately it needs both +/-300vdc so won't be the easiest to implement.Hmm... John Broskie has shown the balanced version of the Aikido many times but doesn't yet offer his boards for it yet (although he prototyped them already). Nowhere in what he's shared is a bipolar supply. All the versions he has shown have been just B+ ~ 300vdc. If you build point to point, one doesn't need to wait for Broskie to build a balanced Aikido all the details are already there. But you don't really have to do a balanced Aikido to get a balanced output either. There are more than one way to skin a cat. There are pluses and minuses for every method. Pick your poison. If you use an output transformer (1:1, splitting, step down, whatever) you can easily derive a balanced output.
Just a little update. I finally built the second F4 up to enable balanced 100w Class A monoblocks. Since the Conrad heatsinks work so well, I was able to bias them a bit higher than before (about 0.6A per device). Nice and toasty for the winter months.Now on to the Pumpkin/Shunty balanced preamp project to swing the F4's to full output and finish up an F5 for the top end of my CS2's.
What he shared with me was quite different from the hints on TCJ, with just a pair of 6SN7's. Very interesting design.I realize there are a lot of ways to do it, which is why I'm putting together the Pumpkin preamp with dual mono shunt supplies Should be a fun project, but so far assembling all the parts is a major challenge and it's more expensive than you might think without a rich parts bin to draw from.
Congrats on building your F4 amps! I hope you're still finding them as enjoyable as ever. I know this is an old thread but as you're so experienced with operating the F4 as a balanced mono block I hope you can advise me. I want to use my stock F4 in balanced mono mode to drive a ~ 90db SPL/w/m center channel speaker. As the F4 does 100 watts, my room's only ~ 2800 cu ft and I'd be only 13 ft away how much input signal voltage could the F4 really need, even to sound it's best under these conditions? That's why I wanted to know if you or someone you know has ever put a balanced passive preamp between the F4 and a balanced output source-like a multichannel DAC, which will have a ~ 4.6V output. Would there any loss in sound quality using a passive preamp like these, assuming their balanced stereo passive outputs could be bridged to feed the F4's balanced input? https://khozmo.com/product-category/preamplifiers/
