volume levels--RCA vs XLR
0 Members and 1 Guest are viewing this topic. Read 1344 times.
tcmo
« on: 5 Mar 2008, 02:10 pm »
I use XLR cables between a BP-20 and 4B-ST.  If I move the volume control from 7 o'clock (off) to 9 o'clock it is too loud.  Would using RCA fitted cables give more usable volume control?  My understanding is that it would.  My sources are balanced.
Thank you.
  • The Demo is Everything!
    • http://www.bryston.com
Re: volume levels--RCA vs XLR
« Reply #1 on: 5 Mar 2008, 03:47 pm »
Thank you.
Hi,
Yes Balanced circuits add 6dB of GAIN (volume) so using the RCA connectors would provide more volume control range.
james
rob80b
« Reply #2 on: 5 Mar 2008, 03:53 pm »
I guess it comes down to what is too loud, are you just trying to adjust the volume to a low background level or is it really LOUD at 9 o’clock? In which case you either have extremely efficient speakers or your source has a very high output.
I have my 3BST and BP25P wired with both RCA and XLR simultaneously, the RCA’s run via the Velodyne x-over, while the XLR’s run direct to the 3B allowing me to bypass the Velodyne. I’ve not noticed any appreciable change in volume when switching from one or the other, I'll try to verify this later on this evening.
tcmo
« Reply #3 on: 5 Mar 2008, 04:53 pm »
Thank you for your reply.
