I'm thinking about leaning towards an 18-55 VR + a 70-300VR in a month or two (or the reverse order.) Does anyone think 2.8 is worth the extra $280 over the nikkor 18-55 3.5-5.6 VR? It seems to me that the shutter speed increase just isn't significant enough in available light indoors. You would still have to use a flash, in which case, I'm really trading off depth of field, not shutter speed. I'll have the telephoto if I want DOF...
jqp: Best of luck on camera body choice! I vote you get the D3, but then you won't be able to use that lens except at 5.6mp. I think I will resist getting the 18-200 because I could practically get the sigma 17-50 2.8 and the 55-200vr for the same price and superior optics. Mainly, my experience with the sigma 18-200 turned me off a little, heh.
Just how much faster shutter speed would I get at f/2,8 if at f/5.6 I get 1/3 second? With sigma OS, I got usable snapshots, but if the shutter speed only bumps up to 1/8 or 1/15 without stabilization, I think that extra speed might be rendered null.
... using a stofen diffusor.I'm going to play with my 1.8 50mm at 2.8 and see what kinds of circumstances would have enough light to benefit from the faster shutter speed. More comments are welcome.
ooheadsoo,Buy whatever you can afford. if spending a extra $300 is out of your price range then don't bother getting 2.8 lenses even though they are better. Sometimes an extra stop could mean the difference between a sharp image to a blurry image.I can only recommend you get the best lenses because I know people who have bought cheap lenses only to spend more money in the end to get a better ones- I have a 70-200 2.8 IS from canon that i spent $2600 on a few years back but I know it will continue using it as long as they are compatible to Canon bodies.
