Has anyone tried these Yaqin Tube Buffers ???
0 Members and 1 Guest are viewing this topic. Read 1104 times.
HiFiSoundGuy
« Last Edit: 29 Feb 2008, 12:02 am by HiFiSoundGuy »
Tweaker
Re: Has anyone tried these Yaqin Tube Buffers ???
« Reply #1 on: 29 Feb 2008, 02:17 am »
I have one. I found that it really doesn't do much except roll off the highs ever so slightly. I ddn't hear it add any "tube sound", it's really pretty neutral sounding. It's said  that with a good aftermarket power cord and the right tube (one of the Jan Philips, I think), that it can make an improvement. I've not tried either, yet. I have mine driving my subwoofer which did make an improvement in the systems sound. Relieving the preamp from the burden of having to drive a long set of sub woofer cables is why, I'm guessing.
woodsyi
« Reply #2 on: 29 Feb 2008, 06:07 pm »
They make any source component "world reference" class especially when you damp the tubes with concrete sealers.  :lol: :lol:
doug s.
  • makin' music
« Reply #3 on: 29 Feb 2008, 08:09 pm »
i never tried one, but over on the head-fi forum a coupla folks have said they're better than the more expensive musical fidelity tube buffer, w/the aforementioned power cord & tube upgrade.
i have a couple tube buffers - two slightly modded ase z-man tube buffers, & a kailin tube buffer.  i have used them to good effect between tuner & preamp, between dac & preamp.  i am presently using one between deqx & amp in my system, on the hi-pass side..
doug s.
K.C.
« Reply #4 on: 6 Mar 2008, 07:43 am »
Yes they do something. What depends on the tube and the source, not so much the AC cord in my experience.
I have both the original MF X10D and the V3. The original is fun because you can roll tubes and find a sound you like. I've got some Mullards in mine that sound warm and wonderful. The V3 on the other hand is very neutral and very nice for digital sources.
