Blu-Ray machine with 480i via HDMI
0 Members and 1 Guest are viewing this topic. Read 1937 times.
alan422
« on: 25 Feb 2008, 11:40 am »
I'm looking for a Blu-Ray machine that supports a pure unmessed with 480i bitstream via HDMI for my outboard video scaler/processor.
I see Sony has one (BDP-S500) but it looks like the video dept. is auto select only.  I'm afraid of getting a machine that supports 480i but won't be able to maually select it for my processor needs.
Any ideas?
samplesj
Re: Blu-Ray machine with 480i via HDMI
« Reply #1 on: 25 Feb 2008, 01:20 pm »
Why???????
Why would you throw away data only to make it back up with scaling.
Even the best scaler's guess isn't as good as the true data.
alan422
« Reply #2 on: 25 Feb 2008, 02:58 pm »
Why?
Because professional grade high-end processors have much more advanced de-interlacing algorithms than what you will find in DVD players, resulting in cleaner, sharper video.  Not to mention the overall better quality video adjustment.
Hope that answers your question...
ted_b
« Reply #3 on: 25 Feb 2008, 04:29 pm »
Why???????
He's talking about SD scaling (where the true data is indeed 480i), not BD of course.  A transport that sends 480i native to a scaler is a good thing.
jonwb
« Reply #4 on: 25 Feb 2008, 04:30 pm »
Alan, do you already have this processor?  If so, what did you get?
samplesj
« Reply #5 on: 25 Feb 2008, 04:49 pm »
Why?
I can't tell from your response, but you do know that Blu is 1080p24hz native on the disk right?  With a Blu disk you don't want to be touching that with ANY scaler (unless you need to go down).
Andrikos
« Reply #6 on: 25 Feb 2008, 05:29 pm »
alan422
« Reply #7 on: 25 Feb 2008, 05:42 pm »
It's a Gennum VXP.  It's actually built into my Anthem D2 processor.  My current DVD player will output 480p.  With that I am able to take advantage of the scalling capabilities of the chip but not de-interlacing.  It needs a raw 480i for that.
I haven't done much looking around yet but I did see a Denon machine that will support 480i HDMI.  I'm sure they have that feature for use with outboard processors.  It's more of a high-end machine and didnt like the price.
samplesj
« Reply #8 on: 25 Feb 2008, 05:51 pm »
Why not just buy a PS3 and then buy a cheaper DVD player that will support 480i?
You don't NEED (or even want) the blu player to support 480i for the actual HD content.  The PS3+DVD player would probably be much cheaper than any future blu player with that feature and is at least as upgradable (if not more).
ted_b
« Reply #9 on: 25 Feb 2008, 06:12 pm »
Agreed.  I use a $169 Oppo 980 for 480i needs (and mch hi-rez), and a Sammy 1400 for BD.
