0 Members and 1 Guest are viewing this topic. Read 9947 times.
Power Wraps also benefit audio and video interconnect cables. They improve the performance of low- and medium-priced cables for lessthan one would spend on a more expensive cable. They are especially helpful on non-shielded cables. The All Clear version of PowerWraps has a smaller diameter, which is more suited to interconnects.
So, Wayner, you've got me worried with all this hum talk. ...............Anyway, I don't think I can afford both the Cardas tonearm rewire and the fluid damper, which should I go with ( I still think fluid damper would be more significant sonically, but I'm not sure now)? Is the SL-1200 worth it or is the hum that significant an issue?
Toka - Wayner's SL-1200 was bought new (mine was beaten to hell used)
The hum is all but gone. The new mat sandwhich did it..........Wayner
