VMPS RM1a
0 Members and 1 Guest are viewing this topic. Read 2865 times.
sharper
VMPS RM1a
« on: 6 Oct 2003, 02:54 pm »
Brian,
         Jim Romeyn mentioned, in a recent post, that there will be an update to the RM1, called the RM1a, coming out in mid-October. According to his post, the only change is that the twin 8s are replaced with a 10" woofer. Can you confirm? What will the difference in the sound be between the RM1 and 1a?
Scott
Brian Cheney
    • http://www.vmpsaudio.com
rm1a
« Reply #1 on: 6 Oct 2003, 03:04 pm »
Prototypes aren't finished, I will keep you posted.
I had had many requests for a Megawoofer version of the RM1, and I don't make 8" woofers.  I haven't found a satisfactory commercial driver, so I will employ our time-tested 80oz 10" in the RM 1 and see what happens.
JoshK
VMPS RM1a
« Reply #2 on: 6 Oct 2003, 06:09 pm »
How well will that integrate w/o a midbass driver?  Curious...
HarleyMYK
VMPS RM1a
« Reply #3 on: 26 Nov 2003, 01:00 am »
Any update?  Is there a prototype to listen to yet?
audiochef
Rm1a
« Reply #4 on: 26 Nov 2003, 04:58 am »
Joshk,  Rm2s don't have mid bass driver.
big gun junge
VMPS RM1a
« Reply #5 on: 26 Nov 2003, 05:13 am »
Funny enough, I ordered a pair of these new RM1s. And like he said, they are not done yet. Looking forward in anticipation.
audiochef
RM1as
« Reply #6 on: 26 Nov 2003, 05:31 am »
Friend of mine has owned RM1as for 2 and a half years now and is drooling over the out come of 1As. Only upgrade he's done is midrange tweak w/  very positive results.
James Romeyn
VMPS RM1a
« Reply #7 on: 26 Nov 2003, 07:28 pm »
The RM2 Xs from its Megawoofer 12 directly to the mids, so obviously the same bass motor driving a 10 will perform well Xd to the same midrange.  Any 10 will naturally extend higher than the same motor with a 12, a function of it's lighter & smaller cone.
