Do I need attenuators??????
0 Members and 1 Guest are viewing this topic. Read 8810 times.
rydenfan
Re: Do I need attenuators??????
« Reply #20 on: 20 Feb 2008, 08:48 pm »
and the sound quality is decent.
Only decent? Could you elaborate a little more?
richidoo
« Reply #21 on: 20 Feb 2008, 11:56 pm »
If I remember the pre-release gossip on the TP, they solved this problem by putting jumpers inside the case which can be set -6 or -12dB to adjust the player to work directly with amps without fear of speaker damage. Maybe Modwright removes these as part of the output stage upgrade, but they might still be there. Maybe check the stock TP online owner's manual.
EDIT:http://www.slimdevices.com/documentation/Transporter-Owners-Guide.pdf
See page 24. It allows -10, 20, 30dB, and 0, of course. You may not need an attenuator if these are still in place.
Rich
« Last Edit: 21 Feb 2008, 12:46 am by richidoo »
rydenfan
« Reply #22 on: 21 Feb 2008, 01:27 am »
Those are only for the non-balanced output, I run balanced. And yes, Dan disables it as part of his modifications.
Charles Calkins
« Reply #23 on: 21 Feb 2008, 02:23 am »
Need a preamp? I'll loan one to you so you can relax and just enjoy the music.GEEEEZZZZEEEE!!!! What a can of worms!!
        Cheers
        Charlie
rydenfan
« Reply #24 on: 21 Feb 2008, 03:10 am »
You seem more freaked out than I do. I have already said I am going to try it tomorrow when it arrives and go from there. Either I will need attenuators or I wont. Not much else I can do...
ted_b
« Reply #25 on: 21 Feb 2008, 04:20 am »
I am currently running my MWTP straight into my McCormack DNA-500.  I'm trying some HT P2A XLR interconnects (active, battery powered fiber-optic) and my two pre's are out of the picture (LS 36.5 being tweaked by Dan; Bent TAP is passive and doesn't drive the P2A's).  The sound is very good, even though the volume control doesn't go much above -30db.
rydenfan
« Reply #26 on: 21 Feb 2008, 03:09 pm »
Thanks for the info Ted. Would the tweaking on your 36.5 perhaps be a new power supply?  :drool:
Charles Calkins
« Reply #27 on: 22 Feb 2008, 06:10 pm »
Hey!!
 Did you get the TP up and running? Any problems? Need attenuaters?
                                    Cheers
                                     Charlie
rydenfan
« Reply #28 on: 22 Feb 2008, 06:10 pm »
Going to set it up right now!!
Charles Calkins
« Reply #29 on: 22 Feb 2008, 06:11 pm »
Keep us posted!
                      Cheers
                     Charlie
