transporter volume controls
0 Members and 1 Guest are viewing this topic. Read 2119 times.
accent
« on: 20 Feb 2008, 03:23 am »
  Since it apears you can use the transporter as a preamp of a sort, does it retain volume levels between inputs ?
 or do you have to adjust each time you change inputs?
        Michael
ted_b
Re: transporter volume controls
« Reply #1 on: 20 Feb 2008, 04:49 am »
It has a digital input menu (to choose one of four inputs) then Music Server, Squeeze Network, Internet Radio, etc.   The volume remains the same for any "input".  If using a preamp, you can set the digital volume to be disabled too.
Owners guide here:
http://www.slimdevices.com/documentation/Transporter-Owners-Guide.pdf
accent
« Reply #2 on: 21 Feb 2008, 01:02 am »
 So lets say I wanted to listen to my 10B  and volume was set at  10 , and I flipped the input to my 350B and was listening to it at 7  I could flip back and forth without having to readjust volumes?   Same for my 9100es at 9 and my Acute at 8 ?
    Just trying to decide how viable this might be for comparisons, I constantly have to readjust my X1 when switching between sources such as my tuners which output at differant levels.
ted_b
« Reply #3 on: 21 Feb 2008, 03:49 am »
No, volume stays the same.  The TP is not designed as a preamp.
accent
« Reply #4 on: 22 Feb 2008, 03:07 pm »
Oh well, then i'll just wait
