TLP
0 Members and 1 Guest are viewing this topic. Read 1606 times.
T-Bone
TLP
« on: 13 Feb 2008, 04:00 pm »
Hi Hugh,
Hope this finds you well and in good spirits!  :)
I have four questions when you have a moment;
1.) Can I use a full wave rectifier instead of the four IN4007 diodes?
2.) If so, what volt/amp rating?
3.) What is the output impedance of the TLP?
4.) Changing over to a stepped attenuator. What value do you recommend?
I'll send you a photo when finished.
Thanks again for a wonderful preamp design!
Brad Kizer
AKSA
    • http://www.aksaonline.com
Re: TLP
« Reply #1 on: 14 Feb 2008, 12:17 am »
Hi Brad,
Thanks for your post, nice to hear from you.  I see your state is very important in the primaries!
Good news, the configuration of the four diodes is in fact full wave!!  I prefer this above all others.
The rectifiers used are 1A continuous, 10A surge, 600 PIV.
Zout is recip gm of the tube, which is around 130R.
I recommend a 20K, or thereabouts.  This is well handled by the SS section of the most sources, and gives low noise.
Hope this helps!
Hugh
T-Bone
Re: TLP
« Reply #2 on: 14 Feb 2008, 04:50 pm »
Hi Hugh,
I didn't word my question properly but as always you seem to know where I'm going. :D Must have been the countless hours you spent schooling me many years ago on my first AKSA 55 build. :wink:
This primary thing here in Ohio has alot of folks up in the air...I personally don't care for any of them, on either side but thats just me.  :scratch:
Anyway, thanks for your help.
Brad Kizer
