Using NEO 3 in a 1st order crossover design
rca9449
« on: 13 Feb 2008, 06:01 am »
Hello Danny,
Would you recommend using the NEO 3 tweeter in a 1st order crossover design on open baffle.  I plan to use a 10" vintage wide range speaker with a NEO 3 tweeter in each cabinet crossing at 2000hz with just a single 20uf capacitor for the high and a single inductor for the low.
rca
« Last Edit: 13 Feb 2008, 06:45 am by rca9449 »
Danny Richie
Re: Using NEO 3 in a 1st order crossover design
« Reply #1 on: 13 Feb 2008, 05:12 pm »
All my measurements suggest using at least a 2nd order crossover.
rca9449
« Reply #2 on: 13 Feb 2008, 06:33 pm »
Thanks Danny.
