0 Members and 1 Guest are viewing this topic. Read 97286 times.
I've had the WLM Diva Monitors (97db) since January and the RWA 30.2 amp since June.I've had some difficulty getting a satisfying response in the highs from the WLM Diva speakers. I've tried Bryston, Conrad-Johnson, and McCormack solid state amps and also I have the Almarro 318B. The solid state amps all exhibited a harshness in the highs. The Almarro is is very satisfying with these speakers, but is rather inconvenient for daily usage. The Almarro burns really hot and takes 3 minutes to warm up before music can be head. I use the same audio system for TV/DVD/hi-fi and I'd rather not burn tubes while watching TV.The 30.2 offers a sound remarkably similar to the Almarro tube amp. Both of these amps have synergy with the WLM speakers. The 30.2 has a slightly larger soundstage with greater separation of instruments. The Almarro has a punchier lower-mid range and twinkling highs. I don't really have a preference between these two amps and switch between them for variety. However, the RWA 30.2 is the every day amp as it is more convenient to use. Both are used for serious music listening.
Does nayone have experience with the Red Wine 30.2 and Decware speakers? Specifically the HDT's?
After scanning this thread I didn't see any Thiels being used with the RWA amps. My interest is mainly the 30.2 integrated. Would this work my Thiel CS 1.6s? They are a 4 ohm speaker and as I understand not easy to drive. Also have Meadowlark Audio Kestrel HRs which I believe are an easy load. Thanks for any input.
I was having great luck with the Harbeth Compact 7ES-3's, but just moved upto 40.1's. Great combination, either way....Perfect for a small room!
I heard most of the rooms at the Venetian, and the only ones that competed with the RWA/WLM room had gear costing at least triple your room Vinnie. Many rooms with more than triple the cost of parts didn't sound as good. VERY impressive!
Anyone tried their Sig. 30.2's with any of the Triangle floorstanders? I have a line on a pair of Antal ESW's (91dB, 8 ohm with a 3.5-4 minimum I think) and am curious about the power requirement. I'm also curious about other impressions of the pairing.~Ben
