0 Members and 1 Guest are viewing this topic. Read 8076 times.
Quote from: reomi on 8 Feb 2008, 08:51 pmWhere does one find the blue teflon tube sockets?DIY HiFi Supply... http://www.diyhifisupply.com/diyhs_sockets.htm
Ray,Just to throw a bit of confound into the works -- partsconnexion sells an Elma 2 to 6 position, single deck (2 poles per deck) srotary selector switch for $40. These are probably not the hard gold contact version, but you can't go wrong either way. You can pin these for anything from 2 to 6 positions. DACT also makes a 5 position selector switch, but at $85 is not cheap. Then there is Shalco as well.I will probably order some of these diyhifisupply teflon sockets, and hope they are better than the earlier teflon sockets of a few years ago, wh9ich were reported to have long term problems with maintaining contact grip. If you want to stick with ceramics -- the Azumas are actually very nice, but they don't have an octal PC mount.I'm putting a PEC pot in my single-ended amp project, and these are supposed to be very nice too.As for switching both hot and ground -- yes, it saves some money to run a common ground, but I've always used chassis isolated RCAs with both hot and ground connections switched, and probably always will -- can't say that I ever did an A/B comparison, but just good grounding practice says that having all low level signals travelling the same path and grounding at one same point should be better, and should be considered as a matter of course if you are using dual or pseudo dual mono power supplies, and depending on how the rest of the circuit's grounding is implemented.I think most people simply don't do it because it is extra hardware and labor expense.-- Jim
