RAW Rebuild
Wind Chaser
RAW Rebuild
« on: 3 Feb 2008, 06:20 am »
Danny,
Since you designed the OB2X crossover, can one of the Neo planers be substituted without modification/significant modification to the crossover?  The intent is to make the top end dipolar.
I plan on making the bass module bigger, possibly sealing it up and using No Rez.  Also be looking at replacing all the AC inductors with foil.  Any thoughts or recommendations?
« Last Edit: 3 Feb 2008, 06:35 am by Wind Chaser »
pbrstreetgang
Re: RAW Rebuild
« Reply #1 on: 3 Feb 2008, 09:57 am »
Interesting :thumb:
Danny Richie
Re: RAW Rebuild
« Reply #2 on: 3 Feb 2008, 06:18 pm »
Dropping in a Neo driver would require a complete redesign of the network on the mid and tweeter.
Putting a pair of Neo's back to back is very doable and would likely work out really well.
I think that the inductors that came with the OB2X were Solen perfect lay. That is a good quality OFC inductor. Going to a foil inductor will be a minor change at best. I wouldn't consider it much of an upgrade.
Wind Chaser
Re: RAW Rebuild
« Reply #3 on: 3 Feb 2008, 07:48 pm »
Is that because the Neo is more sensitive than the ribbon?  If the crossover points are the same as the OB-5 (200Hz and 1.8kHz) wouldn't it be more of a matter of a minor change of a few resistors than a wholesale correction?
BTW, the rebuild is necessary due to one of the crossovers being damaged in transport, so I'm just considering my options here.
Danny Richie
Re: RAW Rebuild
« Reply #4 on: 3 Feb 2008, 07:58 pm »
Nope, crossovers aren't just about crossover points. They have to take into account the acoustic output, impedance, and time arrival effects of each driver.
