SP 3.0?
0 Members and 2 Guests are viewing this topic. Read 606059 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP 3.0?
« Reply #1900 on: 13 Mar 2013, 01:00 am »
Ignore my IR question.  I'm an idiot and when I hooked up my amp triggers I plugged the IR in into the trigger in instead of the IR in.  problem quickly solved when I looked at the back of the unit.  :duh: :duh:
 :thumb: :thumb: :thumb:
scb
Re: SP 3.0?
« Reply #1901 on: 14 Mar 2013, 12:02 am »
Playing a 24/192 album from HDTracks through from my Oppo BDP 93 over HDMI, the Classe SSP-800 correctly identifies that the audio is 192khz. The SP3 is only showing 96khz. I tried sending both PCM and bitstream over HDMI and the SP3 would only show 96khz from both.  Over optical, it would see 192
Is this a known issue?
Re: SP 3.0?
« Reply #1902 on: 14 Mar 2013, 12:41 am »
I will ask engineering - it may be a setting.
james
scb
Re: SP 3.0?
« Reply #1903 on: 14 Mar 2013, 01:27 am »
I thought it might be, but the only one I saw was the D/A Sample Rate, which I have set to 192khz
Re: SP 3.0?
« Reply #1904 on: 14 Mar 2013, 01:33 am »
Hi
I think the OPPO will not output 192 on HDMI and down-samples it to 96 but I want to check.  The SP-3 tells you the real sample rate being processed whereas some units tell you want is coming in - want to check on that.
james
Phil A
Re: SP 3.0?
« Reply #1905 on: 14 Mar 2013, 01:50 am »
Oppo players will send out 192kHz and also at 24 bit over HDMI.  When I was using an HDMI audio de-embedder (where I preferred 24/88.2kKz via the DAC vs. my modded Oppo analog outs), I ran an Integra over to John Gatski's (of everythingaudio.net) place as the BDA-1 I had at the time showed I was getting 176kHz.  John has an ATI ADAC2 sample rate converter which shows bit depth.  Unfortunately the Integra truncated the word length to 16 bits.  I've passed 192kHz via an HDMI audio de-embedder from more than one Oppo model into the BDA-1
scb
Re: SP 3.0?
« Reply #1906 on: 14 Mar 2013, 01:59 am »
Hi
james
If it downsampled it and actually sent 96khz, why would the Classe SSP-800 show it as 192khz? I'm pretty sure the Oppos can output 192khz over HDMI
BSMSPEMBA
Re: SP 3.0?
« Reply #1907 on: 14 Mar 2013, 02:58 am »
Hi
james
I have the same problem.  So, I reached out to OPPO to see if the BDP-93 was limited to 96 over HDMI.  It is not.  They confirmed that the BDP-93 will pass through 192 with no problem.  Their feedback was that the SP3 must have a handshake problem that results in the OPPO down-converting to 96.
James, if possible, can your engineers reach out to OPPO to see what the issue is?  It would be great to get this fixed with the next firmware update.
scb
Re: SP 3.0?
« Reply #1908 on: 14 Mar 2013, 09:50 am »
Kal Rubinson's Stereophile review (Music In The Round #55, July, 2012) mentions this issue
Re: SP 3.0?
« Reply #1909 on: 14 Mar 2013, 10:30 am »
[/quote
Yes it is definitely the OPPO as my DUNE player has no issue with 192 over HDMI with the SP3  :scratch:
James
scb
Re: SP 3.0?
« Reply #1910 on: 14 Mar 2013, 11:46 am »
But my Classe processor has no issues getting 192khz from the Oppo...
Re: SP 3.0?
« Reply #1911 on: 14 Mar 2013, 11:51 am »
Yes but what engineering told me is that the SP-3 reads what is actually being processed by the SP-3 while some processors show what bit rate is coming in and not what bit rate is being processed by the chips in the processor - i want to check on whether I am understanding the engineers correctly.  :duh:
james
Re: SP 3.0?
« Reply #1912 on: 14 Mar 2013, 03:07 pm »
OK I am ordering an OPPO player and we will have a look.
james
So There
  • Brystonized
Re: SP 3.0?
« Reply #1913 on: 15 Mar 2013, 08:52 pm »
Thanks for purchasing an Oppo player, James. It's reflective of your and Bryston's commitment to supporting your clients.
I would encourage you to get the BDP-105, as it's positioned at a level commensurate with the interests of Bryston owners, and it has some interesting design features that may be pique your interest as you develop future products.
Best fishes,
Rich
_____________________
Whiney Napa Valley
Eschew obfuscation.
BrystonFan
Re: SP 3.0?
« Reply #1914 on: 15 Mar 2013, 10:01 pm »
I echo those same sentiments.
What other vendor goes to such lengths to replicate a customer's issue in search of a resolution?
A+ James & Bryston  :thumb:
scb
Re: SP 3.0?
« Reply #1915 on: 19 Mar 2013, 12:27 am »
Anyone ever have their SP3 randomly lose network connectivity? Mine was fine since last week but now doesn't want to have an IP address anymore.  set to auto, not static
When i set it to static, then back to auto, it found it again
yartle
Re: SP 3.0?
« Reply #1916 on: 19 Mar 2013, 09:51 am »
Yep, mine does this as well.  I just go into network settings and make a change (doesn't seem to matter what) and then save it and then go in and change it back the IP address comes back.  When it fails it isn't attached to the router at all (checking the MAC address).
ragg987
Re: SP 3.0?
« Reply #1917 on: 19 Mar 2013, 02:57 pm »
I had some network connectivity issues as well. Changed from the default "Server & Client" to "DHCP Client Auto IP" and it is now reliable.
Note - this works for me as my router provides DHCP services. If your network is different, you may need a different solution. Have you seen the guidelines in the Bryston FTP area? ftp://bryston.com/pub/firmware/sp3/doc/
scb
Re: SP 3.0?
« Reply #1918 on: 19 Mar 2013, 02:58 pm »
Mine's already set to "DHCP Client Auto IP."  I had to set it to a different setting and then back to "DHCP Client Auto IP" for it to get an IP address last night
Alpha10
Re: SP 3.0?
« Reply #1919 on: 19 Mar 2013, 03:09 pm »
Hi James, just following up on this, I had never looked at the rates before on the SP3.
I have a much older Oppo 83SE (still hoping you will build me a replacement Bryston Bluray to replace it eventually   :oops:) anyway, I tried a couple of things, connected up over HDMI if I put a DVD-Audio disc in the SP3 shows 96kHz correctly, so that it is good, I will have to find some 192kHz to try later. So, to my question, I then left the rate display on the SP3 and ran a couple of Blurays, they always report 48kHz regardless of whether it is bitstream or PCM (I have max LPCM set to 192kHz in the oppo) I tried ordinary DVDs, DTS-MA and DD-True HD all the same always 48kHz, does that sound right?
Cheers
