SP 3.0?
0 Members and 3 Guests are viewing this topic. Read 609950 times.
skunark
Re: SP 3.0?
« Reply #1080 on: 2 Aug 2011, 03:11 am »
I waited awhile for the SP3 to be released and a few months back I finally decided to focus on two channel.   I did entirely expect the SP3 to be released and I would be having regrets right about now, but now it appears I'm glad I made the switch to just two channel and disappointed that I can't do a dealer demo of the SP3.
Vipers
Re: SP 3.0?
« Reply #1081 on: 25 Aug 2011, 04:24 pm »
Hi James,
Those pics of the SP3 that were in the factory tour thread have got us Brits a little excited on the other side of the pond, a quick question if you don't mind.
I've been wondering that if I was to go with the SP3 for my movies and 2ch duties, I guess I could sell my BP26 and possibly my BDA-1, I know in the past you have said the SP3 performs as well as the BP26 for 2ch, but would you recommend keeping the BDA-1? or is the DAC section in the SP3 as good as the BDA-1? Which if it is actually makes the SP3 great value.
Thanks.
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP 3.0?
« Reply #1082 on: 25 Aug 2011, 06:00 pm »
Hi James,
Thanks.
Hi Vipers,
I am playing around with the SP3 now using the BDP-1 as the source into the Balanced AESEBU on the SP3 so I should be able to let you know soon.
james
Alpha10
Re: SP 3.0?
« Reply #1083 on: 25 Aug 2011, 06:45 pm »
Perfect  :D
Vipers
Re: SP 3.0?
« Reply #1084 on: 25 Aug 2011, 09:36 pm »
Hi Vipers,
james
Brilliant, thanks James, can't wait to hear your thoughts, it's looking more likely I may be heading down the SP3 route :)
A couple more quick qestions if you don't mind.
Will the SP3 come with it's own remote or will the BR2 be used? will one come in the box?
Looking at the picture on the factory tour thread of you holding the SP3, the back panel seems to have changed slightly from the earlier picture, I can't seem to see the power outlet, will the SP3 be able to be powered from the MPS-2?
Thanks.
Re: SP 3.0?
« Reply #1085 on: 25 Aug 2011, 09:39 pm »
Thanks.
Hi
Yes some of the layout has changed but it must be powered internally due to separate power supplies for the digital and analog stages.
There will be a new remote that looks like the SP2 remote that will come with the unit.
James
BrysTony
Re: SP 3.0?
« Reply #1086 on: 25 Aug 2011, 10:07 pm »
The back panel does not look as tall as the front panel.  There must be a second piece of the back panel that will include the HDMI input/outputs and the power input.
Tony
Re: SP 3.0?
« Reply #1087 on: 25 Aug 2011, 10:31 pm »
Tony
Hi Tony
Correct the one I am holding does not have the top back panel section attached.
James
gdbalp
Re: SP 3.0?
« Reply #1088 on: 26 Aug 2011, 04:31 am »
Hi James,
On the up coming SP 3, will Bryston create an app for IPOD/IPAD to control this unit?
And, any change you can play stored music via the ethernet port?
Ciao, Luigi
Re: SP 3.0?
« Reply #1089 on: 26 Aug 2011, 10:49 am »
Hi James,
Ciao, Luigi
Hi Luigi
No control planned at this point as companies like Crestron make units that will integrate if customers want display control.
There is no harddrive in the SP3 so no storage is available.
james
Vipers
Re: SP 3.0?
« Reply #1090 on: 26 Aug 2011, 11:28 am »
Hi
James
Thanks James, when do you think we may realistically see the SP3 over in the UK?
Re: SP 3.0?
« Reply #1091 on: 26 Aug 2011, 12:42 pm »
I hope by October.
james
Alpha10
Re: SP 3.0?
« Reply #1092 on: 31 Aug 2011, 09:26 pm »
Hi James,
I may have missed it but will the SP3 be a 5 or 20 year warranty product?
Cheers
Re: SP 3.0?
« Reply #1093 on: 31 Aug 2011, 09:29 pm »
Hi James,
Cheers
Being a digital product 5 years.
James
Alpha10
Re: SP 3.0?
« Reply #1094 on: 31 Aug 2011, 09:51 pm »
James
Thank you, I know this is a difficult question, but it this likely to change? I would not want to be an early adopter and miss out (as I just have with my PMC speakers..)
Cheers
Re: SP 3.0?
« Reply #1095 on: 31 Aug 2011, 10:06 pm »
Cheers
No it is not likely to change and if it did it would be retroactive as it was when we went to 20 years on the amps in 1990.
Alpha10
Re: SP 3.0?
« Reply #1096 on: 1 Sep 2011, 08:33 am »
Good to know, thank you.
JeffO
Re: SP 3.0?
« Reply #1097 on: 3 Sep 2011, 04:12 pm »
Hi Vipers,
james
James,
So how does it sound against the BDA?
Also when will you be able to post or publish a finalized feature and spec sheet for the SP3?
Jeff
Re: SP 3.0?
« Reply #1098 on: 3 Sep 2011, 06:13 pm »
James,
Jeff
Hi Jeff
I am working on the manual now - is there a particular spec your interested in?
James
john1970
Re: SP 3.0?
« Reply #1099 on: 3 Sep 2011, 10:30 pm »
Hi James,
Glad to hear that Bryston is getting very close to releasing the SP3.  I just placed my order for a SP3 this week.  I am very much looking forward to having it replace my Bryston SP1.7.  The features I am most looking forward to are:
1) Support for lossless surround sound
2) Support for SACD via HDMI (although it appears that DSD must be first converted to PCM)
3) Lack of video processing which is not worthwhile becaus my Oppo-93 does an excellent job on the video
4) 7.1 analog inputs with 7.1 balanced analog outputs
5) Multiple balanaced sub outputs (1 sub and 2 Aux outputs)
Would it be possible to post a link to the manual for AC members on the Bryston circle once you complete the manual?
John
« Last Edit: 4 Sep 2011, 04:48 pm by john1970 »
