couple of questions Doc....
0 Members and 1 Guest are viewing this topic. Read 2141 times.
dado5
« on: 1 Oct 2003, 03:36 am »
I noticed a slight change in the Ear+ newer(Purist, etc.) designs.  Namely the input is now capacitor coupled to the grid of the 5751.  Why the change? Is it a sonic improvement? Do you recommend it as an upgrade for the original Ear+?
Also will removing the balance control on the older Ear + increase the gain?  If so would a higher value pot serve to lower the gain  somewhat?
I am lovin' the amp... just lookig to get that much more out of it.
Thanks much in advance,
Rob
