0 Members and 1 Guest are viewing this topic. Read 18792 times.
I have read that that a completely dead room is not appropriate but at the same time, any reflections in the listening room are to be avoided. Are these not mutually exclusive goals? Are we talking about primary reflections only?
Quote from: TomW16 on 8 Mar 2008, 04:19 pmI have read that that a completely dead room is not appropriate but at the same time, any reflections in the listening room are to be avoided. Are these not mutually exclusive goals? Are we talking about primary reflections only?As I see it, the problem with a totally dead room is not so much how it makes music from loudspeakers sound. Rather, it makes conversation and everything else you do in the room sound unnatural.--Ethan
If the sound you hear does not reach your ears in a straight line from the speaker driver, it is distortion to the recorded signal.
Of course the lower the frequency the more the tendency of a sound to spread in all directions, whether natural or reproduced.Now the higher the frequency of a sound, the more stark the character of its directionality. When I think of the highest frequency sounds in music I think cymbals first (and triangle second). This sound spreads in all directions. This instrument is (a) high frequency therefore directionality is very important in reproduction and (b) disperses in all directions in real life. This doesn't strengthen the argument for box speakers - cymbals are kind of important.Quote from: bpape on 6 Mar 2008, 12:49 pmExactly. And that's part of why reflections can be so damaging. The reflected sound is not of the same response distribution as the original sound so it not only smears things in time but also mucks up (technical term) the frequency balance.I used to see it that way, but not anymore. You can view the sound that arrives at your ears two ways.
The second way of viewing it is not how it looks in a scope, but how it is perceived by a human listener.
Now human listeners have a lot of in-built 'DSP' for dealing with all kinds of crap that happens with real sounds and real spaces. We are filtering reflections all the time in real life.
Quote from: darrenyeats on 7 Mar 2008, 11:28 pmthat is not what microphones and stereo speakers do. Instead they record the effect of reflections at the microphone position in the performance space, then re-broadcast the effect from just two points in the listening space. The perception of the listening space is an illusion, not a literal reconstruction.I agree with this. All the ambience and reverb etc you want was already captured by the microphones. (Or for pop music, added artificially by the engineers.) The job of loudspeakers is to reproduce that cleanly without interference from early reflections in the much smaller room the speakers are in. I'm sure we all agree that a concert recording heard through headphones can sound huge. So that alone proves that reflections in the listening room are not needed for a realistic sounding and satisfying experience.--Ethan
Exactly. And that's part of why reflections can be so damaging. The reflected sound is not of the same response distribution as the original sound so it not only smears things in time but also mucks up (technical term) the frequency balance.Bryan
I won't speak for either Brian or Ethan, but I'm sure that they would agree with me that a room without walls, a ceiling, or a floor would be the best listening room. In lieu of that, if you want to hear what was really captured by the microphones, as faithfully as possible, room treatments are necessary.Cheers
Quote from: Daygloworange on 10 Mar 2008, 03:34 amI won't speak for either Brian or Ethan, but I'm sure that they would agree with me that a room without walls, a ceiling, or a floor would be the best listening room. In lieu of that, if you want to hear what was really captured by the microphones, as faithfully as possible, room treatments are necessary.CheersDayglo,I have been on that train for many years.If you're ever in LA, you need to call me (if you have an hour or two to kill)
Quote from: John Casler on 10 Mar 2008, 03:48 amQuote from: Daygloworange on 10 Mar 2008, 03:34 amI won't speak for either Brian or Ethan, but I'm sure that they would agree with me that a room without walls, a ceiling, or a floor would be the best listening room. In lieu of that, if you want to hear what was really captured by the microphones, as faithfully as possible, room treatments are necessary.CheersDayglo,I have been on that train for many years.If you're ever in LA, you need to call me (if you have an hour or two to kill)And you shall be shrouded in John's throne!
In a theoritically perfect (sic) 2 channel recording, you would use 2 microphone diaphragms. They would be spaced 6" to 8" apart and angled to match the angle of incidence of a human's ear canals, and with a non reflective divider between them to eliminate channel crosstalk(it actually exists, it's called a binaural dummy head mic). I'll use this 2 mic method to illustrate my example.
I have also used the Center Divider<snip>But it could not be done in a non-dedicated room
Yes, a cymbal radiates sound(evenly) in all directions (most, if not all sound sources do, but not evenly in all frequencies), and causes reflections in the room that it happens to be in. The direct and indirect sounds arrive at your ears in an amplitude ratio, and time domain ratio, and frequency ratios. Your ears pickup the direct sound, and the reflected sounds.Microphones mimic what your ears do in that same situation. The two independant channels of L/R info from the mic's are reproduced with 2 L/R speakers. If you do not introduce any added reflections, eliminate channel crosstalk, and have a very linear high resolution playback system, you will have avery convincing soundstage of the live event.
QuoteThe second way of viewing it is not how it looks in a scope, but how it is perceived by a human listener.In a perfect (sic) 2 (mic) channel recording, you are actually reproducing what is happening at the interface between the source of the sounds, and your ears. QuoteNow human listeners have a lot of in-built 'DSP' for dealing with all kinds of crap that happens with real sounds and real spaces. We are filtering reflections all the time in real life. The brain is fed an input from the sounds your ears capture. Your ears don't filter anything. Microphones are designed to capture sounds like ears do. An audio system's job is to relay what the microphones (in place of your ears) picked up. If the audio system were perfectly linear, what you would be hearing if your earswere in the place of the microphones (which happen to be there in place of your ears).
In fact darrenyeats, the recording in the example I give is a perfect reconstruction of what a listener's ears are capturing.
Daygloworange, Bryan, and Ethan, I wondered if you could comment on the head related transfer function and the effects of the absence of dummy ear molds in simple 2 mic stereo recordings.
I think you misunderstood my point. Yes the microphone picks up what ears would have heard in the original space. The listeners ears pick up the sound re-broadcast from the loudspeakers-or-headphone plus any listening room reflections (if applicable). My question was about how the listener's brain might interpret the sounds in such a fashion as to filter out just the listening room reflections from the experience. As stated I've experienced this illusion and am looking for an explanation. (Of course, it's possible I heard just what I wanted to hear, a personal illusion: it wasn't a DBT or well controlled experiment. I could leave it there but I feel I must know if this is a consistent, repeatable illusion, and if so why it works. )If you don't think this is possible, then that is a different matter to your comments (which I even happen to agree with).
Except, if you're not wearing headphones but listening through speakers, you are listening through two head related transfer functions. First the dummy head at the mics, and second your own. Have I got that right?
What do you think of the Kimber IsoMike approach to recordings? Is this a nearly perfect method of non-binaural recording, in your opinion?
Daygloworange, Bryan, and Ethan, I wondered if you could comment on the head related transfer function and the effects of the absence of dummy ear molds in simple 2 mic stereo recordings. Also, in your theoretically perfect 2 channel recording, how important is it to closely model the actual listener's own head size and ear shape? For example, I have a large head (unfortunately, not a large brain). I have a friend with a much smaller head (he's much smarter) but his ears protrude much more.
How do binaural recordings sound on a non-optimized loudspeaker setup?
Is this part of how pseudo-surround sound works, through signal processing to try to "fool" the ear?
Quote from: youngho on 10 Mar 2008, 04:26 pmIs this part of how pseudo-surround sound works, through signal processing to try to "fool" the ear?All the pseudo surround stuff I've heard uses phase shift trickery to make things sound like they're coming from outside the width of the left-right speaker width. All the gadgets I've heard sounded phony to me, though I haven't heard them all.--Ethan
