Tube Preamps
0 Members and 1 Guest are viewing this topic. Read 12382 times.
guest1632
  • Guest
Re: Tube Preamps
« Reply #40 on: 21 Jan 2008, 09:46 pm »
I am using the Promitheus Apollo preamp with C-core OTPs (version 6922s) and sometimes swapping with this new product preamp using two 8608/8233 output tubes and one GZ34/U52/5U4 rectifier. The picture shows the prototype one. It has >40dB and low impedances.
Hi, I was considering getting the newer TVC with Double C Core. I did write Nick about this and haven't heard back from him yet. Wanted to get the TVC in a single box, like Rev 5, but with the Double C cores in there instead of the standard transformer. I was also thinking about the tube preamp. So here I am looking around.
Ray
Sonny
Re: Tube Preamps
« Reply #41 on: 21 Jan 2008, 09:50 pm »
Ray, I am using the Consonance Cyber 222 pre, which uses 4 6SN7 tubes and a 5AR4 rectifier with great results... on my EVS 500M amps!  New it's only $1495...let me know if you're interested... You can even audition mine...I am in SF Bay Area...
Here's a picture:
Tuan..
guest1632
  • Guest
Re: Tube Preamps
« Reply #42 on: 21 Jan 2008, 10:11 pm »
Here's a picture:
Tuan..
Hi Sonny,
Thanks for the offer. I might consider that I'm here in Tucson. What would you use in the meantime?
Ray
tanchiro58
Re: Tube Preamps
« Reply #43 on: 21 Jan 2008, 10:17 pm »
Ray,
The Apollo preamp is also an excellent preamp. I got an used one in audiogon and replaced all high quality components except the Double C-cores and TVC trans and wires. I personally do not like the sound of 6N1Ps. Therefore, I swapped them with 6922s (since I found a very nice sounding pair of NOS ECC88/6922s in my closet) by following Nicholas instruction. It turns out to be more than excellent preamp which matches my sonic tastes. I had a couple TVCs but somehow there was a sonic weakness in my system with TVC only. So I thought I would need a tube buffer stage for TVC. I also have tried a separate tube preamp used with TVC but that combination did work well in my system too.
Tan
