Eighth Nerve Adapt Triangles IN STOCK!
0 Members and 1 Guest are viewing this topic. Read 5865 times.
8thnerve
« on: 18 Jan 2008, 04:21 pm »
Eighth Nerve Adapt Triangles are in stock in both black and white and are ready to ship!  4 Adapt Triangles will improve your system more than any other upgrade.  See for yourself how the most unique acoustic product delivers the best results.
hmen
Re: Eighth Nerve Adapt Triangles IN STOCK!
« Reply #1 on: 18 Jan 2008, 04:41 pm »
Can the triangles be painted?
8thnerve
« Reply #2 on: 21 Jan 2008, 02:47 pm »
Yes!  I recommend using a little gesso (you can get at an art shop) or if you can't get that, some spray starch to tighten the fabric before painting.  You can paint all around the front and sides of the product, just avoid the felt area on the back.
Best Regards,
Nathan Loyer
Eighth Nerve
