HI-VI B1S
sunnyduce
HI-VI B1S
« on: 17 Jan 2008, 09:53 pm »
Hi All
Any body used these in a line array?On there own not so good,but I wonder about
the sound quality.C-T-C would be really good.
Cheers sunny
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: HI-VI B1S
« Reply #1 on: 25 Jan 2008, 07:26 pm »
Hi All
Cheers sunny
These are similar to the drivers that McIntosh uses. I've heard those and for an entry level array they are decent.
sunnyduce
Re: HI-VI B1S
« Reply #2 on: 26 Jan 2008, 09:34 pm »
Hi Rick
Thank you for answering.I have a boatload of them.I wonder what the little holes
are for.Is it mend to load this in a very small enclosure to get response  correct?
Sunny
Rick Craig
  • Selah Audio
Re: HI-VI B1S
« Reply #3 on: 26 Jan 2008, 09:38 pm »
Hi Rick
Sunny
You might check on the Parts Express board to see if someone there has used them.
sunnyduce
Re: HI-VI B1S
« Reply #4 on: 27 Jan 2008, 01:53 am »
Hi Rick
Thanks,I will check.
Sunny
