0 Members and 1 Guest are viewing this topic. Read 35385 times.
Usually, lower ratio transformers sound best. So, a one to one transformer might give the best sound overall, but would not increase the voltage on the Oppo because it is a single ended DAC.
Another problem with just running a cap out is that the signal is inverted in absolute sense.
I’ve ordered a 5v vreg from www.pilghamaudio.com to replace the 7805 based on mgalusha’s experience with it in his DCX mod.
The only downside is they are limited to 280mA, so hopefully your Oppo doesn't draw more than that.
Hey Mike,Thanks for bringing that vreg to my attention. How many of the regulators are used in the DCX?My hope is that the new regulator plus the felix will get me back to the sound I had with the outboard PS.QuoteThe only downside is they are limited to 280mA, so hopefully your Oppo doesn't draw more than that. Maximum draw for the CS4361 DAC is 90mA, so I should be O.K. Of course, that's what I thought about the other mods I tried. Russ
I wonder if the problems you were having with the external 5V is because the power sequencing. That is, with the 5V reg, the oppo could control when 5V to the dac was turned on, but it lost that control with the external 5V.
Other question is does the Bolder supply put out exactly 5V? A SB won't care if the 5V is high, it goes through other regulators anyway. A DAC will care.
So if you're talking 2 channel HDMi vs S/P-DIF, no, but at least it's "a/b'-able".
After further experimentation, I’ve had to abandon the outboard 5vdc power supply approach to the Oppo 980. This frustrates me because it sounded so good! But I found that after I removed the 7805 regulator, the player started behaving erratically. The transport would sometimes stop reading DVDs and SACDs and the LFE channel stopped working. When I reinstalled the 7805, these issues went away. Is that weird or what?!
