What does everyone use to dust their electronics?
0 Members and 1 Guest are viewing this topic. Read 5605 times.
meby
« on: 7 Jan 2008, 08:10 pm »
The has to be something better than damp towels to dust off components?  I would love to hear what others out there are using to keep their stuff dust free! :scratch:
low.pfile
Re: What does everyone use to dust their electronics?
« Reply #1 on: 7 Jan 2008, 08:40 pm »
I have the same question. was planning on cleaning the dust off of my bookshelf speakers...the grilles are off. plan is just a damp cotton towel. would like to know if something else is more gentle out there especially the driver cones. maybe a certain microfiber used for car detailing would work.
I think I will pick up some pledge for the speaker cabinets.
And damp towel on the electronic enclosures too. and a few blasts of dust off.
I hate that during winter the heater kicks up the dust.
Tweaker
« Reply #2 on: 7 Jan 2008, 08:42 pm »
This is what I use on my electronics and have for years. Works great:
http://www.pledge.com/multi-surface-cleaner/
BobM
« Reply #3 on: 7 Jan 2008, 08:49 pm »
I just use one of those feather duster thingies when my wife yells loud enough that I have to clean up. Then I run a vacuum and am good for the next 6 months  :-)
Bob
toocool4
« Reply #4 on: 7 Jan 2008, 08:50 pm »
I use the Pledge Fluffy Duster. It’s very soft so does not scratch and dirt sticks to it.
Check it out here www.pledge.com/duster-plus.aspx
The one I use does not have the spray it’s just the duster.
giantsteps
« Reply #5 on: 7 Jan 2008, 08:59 pm »
Frank
DTB300
« Reply #6 on: 7 Jan 2008, 09:02 pm »
And she does a fine job....Even better when you watch....
kidding aside...I use Swiffer...
« Reply #7 on: 7 Jan 2008, 09:29 pm »
 :lol:
 :kiss:
TomS
« Reply #8 on: 7 Jan 2008, 09:31 pm »
 :lol:
 :kiss:
If Pledge could just mass produce those at low cost.... THEN you'd have something!
some young guy
« Reply #9 on: 7 Jan 2008, 09:35 pm »
i'll either blow it off with:
...or i'll use the swiffer. it's great for getting in underneath components too.
electricbear
« Reply #10 on: 7 Jan 2008, 09:55 pm »
I use the Billybags audio duster. It's a black sheepskin duster that works wonders. Be careful when using wax based polishes on wood grained speakers. The grain can get full of the wax and you will loose some of that nice wood finish. There are many manufacturers that actually state in their owners manuals not to use polishes that contain wax
Wayner
« Reply #11 on: 7 Jan 2008, 10:57 pm »
Damp cloth works for me. No wax, maybe very mild detergent & water for hard to get off spots (finger prints on brushed aluminum). I use the same type towel that I use to clean my glasses with.
Wayner  :wave:
some young guy
« Reply #12 on: 7 Jan 2008, 11:14 pm »
cloth diapers work great for things like that.
Photon46
« Reply #13 on: 7 Jan 2008, 11:30 pm »
I use an ostrich feather duster every week. You can stir up a good air flow to scatter dust out of areas that are hard to reach with it. Somethimes I blow out the undersides with canned air.
*Scotty*
« Reply #14 on: 7 Jan 2008, 11:42 pm »
I use windex on anodized aluminum and Meguier's Cleaner Wax on my loudspeakers 9 coat polyurethane finish. It protects the finish from UV that might get through the windows in the room. I apply the Mequiers once a year and use a damp cloth for dusting the rest of the time followed by
dry towel. I vacuum the midrange and woofer driver cones as needed the planer magnetic tweeter I leave alone.
Scotty
some young guy
« Reply #15 on: 7 Jan 2008, 11:51 pm »
 :D i do that too...
JoshK
« Reply #16 on: 8 Jan 2008, 02:02 am »
My hand followed by a wipe on my jeans.
Bob in St. Louis
« Reply #17 on: 8 Jan 2008, 11:44 am »
You get points for your honesty dude!
I use compressed air and a blow gun. Not the wimpy canned stuff, I mean a compressor. Certain areas require a lighter touch like driver cones and cooling fan blades but it works well. The best part is you're not touching the item leaving scratches.
On a nice day, I'll open all of the doors and windows and dust the entire room with this method. Works well.
Bob
  • Speakers....What Speakers ?
« Reply #18 on: 8 Jan 2008, 12:23 pm »
I thought dust was another "layer of protection".... :lol:
I use a chamois.... :thumb:
denjo
« Reply #19 on: 8 Jan 2008, 12:43 pm »
I use a brush with horse hair and it works fine! As for my Altmann Attraction DAC, I use a hair dryer set to "cool" and simply blow the dust from the DAC!  :wink:
