emspeaker LB12 fieldcoil -fullrange-98db
0 Members and 1 Guest are viewing this topic. Read 2607 times.
Mozart
« on: 3 Jan 2008, 03:46 pm »
                         www.emspeaker.fr/
 Emspeaker has introduced their new line of high-efficiency drivers: the emspeaker LB12ex and LB12.
 The LB12EX is a field coild drivers-98db-16ohm using a paper cone with a nomex paper v.c former.
 Being a full range driver (40hz-15khz +-4db)- they will be greatly appreciated with
 set lovers.
 You can have exactly the same driver (the LB12) with a ferrite magnet.
Mozart
Re: emspeaker LB12
« Reply #1 on: 16 Sep 2008, 08:17 pm »
 Free shipping to continental US -until oct. 31st.....
Emspeaker has just introduced a new full range driver the: Emspeaker LB7 - a  7inch - full range driver (40hz-18khz)
  -high efficient-low qts = fast driver.
Can be used in a TL cabinet:
(Plan for TL cabinet included with purchase)
A one driver solution at a very affordable price.
Contact me for additional info or www.emspeaker.fr/
 Here are the specs:
-Z at 440Hz: 15ohms
-FR: 40Hz
-Qms: 3,770
-Qes: 0,228
-Qts: 0,215
-Mms: 7gr
-Vas: 56L
-BL: 9,66
-Eff: 94,1dB
-Xmax: 3mm
-Acc.factor: 1380
-frequency response: Fx to 18000Hz
konut
Re: emspeaker LB12
« Reply #2 on: 16 Sep 2008, 09:04 pm »
And what would that be? The price I mean.  aa
