0 Members and 1 Guest are viewing this topic. Read 15111 times.
Can I get the OB7 with a non-veneered curved front baffle? (any pics of that curve?)
And do I need to biscuit join the frames to the external panels or are they pegged?
While I'm at it, still doing any of the LS cabinets?
1) What do you suggest as far as the gasket material?
2) How do the bases attach to the bottom? Is the intention to drill a hole through the larger recessed holes in the bottom of the base, through the bottom of the cabinet, and into the hollowed out false bottom -and then screw all three together?
Is it best to drill out the driver holes first before gluing on the front baffle? or after so its got something to support it?
Should I take a driver and mark the holes with the pencil into the mdf -using the driver as a template?
Denny, would you be able to share any pictures of how you did the false bottoms? I was looking at the base and I think I am going to have to move the gasket to the outside for there to be space to line up with those screw holes. I put the gasket just a smidge away from the center cutout. I was thinking the gasket should be inside the holes. Also, should I caulk the edges to make sure its airtight? If so, what kind of caulk, a silicone?
