My OB4A's??
0 Members and 1 Guest are viewing this topic. Read 14703 times.
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
Re: My OB4A's??
« Reply #40 on: 8 Jan 2008, 10:08 pm »
Thanks for the comments guys.
KLH, Mine are 48" tall.  It is my understanding that D'Appolito configurations are suppose to be extra sensitive to tweeter position with regard to alignment with the ear.  When I asked Danny how low I could place the tweeter he said between 36" and 40", basically at ear level when seated.  I can tell you that the speaker still sounds great when I stand up so there is some play there.  I'm not certain how going shorter and leaning the speaker back would affect the sound.
Best,
Ed
Danny,  How far under the tweeter before you compromise sound quality?
If the tweeter is centered at 40" on the ob7... How many inches under that can you safely go? - my couch is this lazyboy reclining thing that sits low and reclines even lower. I think about 34" ear height...
Danny Richie
Re: My OB4A's??
« Reply #41 on: 8 Jan 2008, 10:57 pm »
If you need to you can shorten a few inches with no problem.
It maintains a very good and very even off axis response in the vertical range.
Here is an OB-7 plus vertical off axis:
This is from only 1 meter away and each measurement was made moving the mic up 4" at a time. So on axis (red), up 4" (orange), up 8" (yellow) and up 12" (green).
The standard OB-7 looks even better.
ttan98
Re: My OB4A's??
« Reply #42 on: 11 Jan 2008, 08:36 pm »
Ebag4 or Danny,
I am thinking of using 2*M130 in MTM configuration, are you using the 16ohm version or the 8ohm version.
The latter gives a slight better effciency about 96db which is compatible with the neo ribbon tweeter, hence no need for resistive attenuation and possibly easier x-over design between neo and M130.
I have 2*M130(8 ohm version) already, buying additional 2 units then I am ready to rock.
ebag4
Re: My OB4A's??
« Reply #43 on: 11 Jan 2008, 08:50 pm »
Ebag4 or Danny,
..... are you using the 16ohm version or the 8ohm version.
The OB5/7 use the 16 ohm drivers in parallel for the MTM section, that is what I am using.
emac
Re: My OB4A's??
« Reply #44 on: 8 Apr 2008, 04:57 pm »
At some point I may try a version of this speaker using the same MTM section but try a pair of the SW-12-16FR woofers below it. Those are the new 12" Direct Servo controlled woofers that are designed to operate in free air.
The bottom end control should be great, but the question is will they play up high enough to reach them with the highest crossover point on the plate amps being 160Hz. We'll see.
Any word on the OB MTM + 12" Direct Servo woofers?  These would definitely be speakers I'd take a long look at getting.
Danny Richie
Re: My OB4A's??
« Reply #45 on: 8 Apr 2008, 06:23 pm »
Denny and I have been working on this new model (enclosure design). There are a lot of really new things going into this model that takes everything to the next level.
I won't be offering it as a kit though. It is a little too involved to be a kit. It will be offered fully assembled and ready to play.
emac
Re: My OB4A's??
« Reply #46 on: 8 Apr 2008, 06:43 pm »
Now my interest has really been piqued.  Can't wait to hear more about it.
Danny Richie
Re: My OB4A's??
« Reply #47 on: 9 Apr 2008, 05:57 pm »
I can't wait to tell you guys more about this speaker but can't just yet.
Hank
Re: My OB4A's??
« Reply #48 on: 9 Apr 2008, 06:02 pm »
And I'm waiting on the next, next level:  your OB Line Array of the future - how's that coming along?
Not saying, eh?
« Last Edit: 14 Apr 2008, 05:09 pm by Hank »
bz79
    • cz photography
Re: My OB4A's??
« Reply #49 on: 11 Apr 2008, 02:18 pm »
Who will it be assembled by, GR Research or will it be like the LS-6 and LS-9 and be built by AV123?
Daygloworange
  • www.customconcepts.ca
Re: My OB4A's??
« Reply #50 on: 11 Apr 2008, 02:30 pm »
It's a collaborative effort between us and GR Research that has been evolving over the course of the year, it is still a ways off from being finalized. We are still in the testing phase of a number of features that will make this a really unique speaker system. We're not saying what it will be, yet. We will debut it at RMAF 2008 in the GR Research room.
And there's more.... :wink:
Cheers
bz79
    • cz photography
Re: My OB4A's??
« Reply #51 on: 11 Apr 2008, 05:25 pm »
Cheers
Cool thanks!  8)
