0 Members and 1 Guest are viewing this topic. Read 6067 times.
This is a good start...would like to see this digital crossover rolled out for the whole line.
Hi JohnWhat crossovers and slopes is Brian recommending for the RM30's? I have played around with these using the Tact digital amps and crossovers and struggled to get a good cross between woofers and panels.RegardsJose
This is awesome stuff. The DCX is proving to be a VERY versatile piece of hardware, indeed!-Jim
so why spend 400 or 1200 on caps with this new cheap deqx?
John,It looks like the DCX has only XLR connections. Will the RM30 SDE come with converters for RCA? If not, how much more for those? Also, you mention a passive attenuator that will do away with a pre-amp. Where does the attenuator go?
So this begs the question, which way to go?The RM30 SDE or the RM40jr with direct drive and wait for the digital curves to be worked out for that?I currently have a Van Alstine Ultimate 70, it would be great to run that for the ribbons and the tweeter, and use the analogue crossover for that, no? Or would I be better off just getting some nice quality but low powered, like 3.5 watt SET or some 10 watt tube amp?I have a Sony ES 9000 amp that gives me 5 channels at 125 watts. I have a pair of smaller VMPS subs and currently run them with the amp bridged but could set it up so that two channels drive the subs and two channels drive the bass end of the speakers. I could use two channels for the bass, two channels for the tweeter , and use the U70 for the mids and get another beefy cheap solid state amp to drive the subs.I use this in a home theater set up though I mainly listen to 2 channel sound. Would I be able to take the digital out (record) from the Pioneer VSX 59i, run it in to digital crossover and still get surround sound from the amps in the receiver? I am guessing that wouldn't work as I would only get two channel digital out from the receiver.I had looked at the NHT XD and though the digitial implementation seems more speaker specific this looks like a much more amazing set up in comparison.thanks!
