TVC input and output Impedance?
0 Members and 1 Guest are viewing this topic. Read 3162 times.
Wind Chaser
« on: 19 Dec 2007, 02:10 am »
#1 - Does the TVC take a high impedance input and lower it at the output?
#2 - Has anyone found the volume control to be an issue?
Thanks.
Gaara
Re: TVC input and output Impedance?
« Reply #1 on: 19 Dec 2007, 11:53 pm »
1.  Yes depending on the output level, I believe the last couple steps like -2db and 0 are actually a higher impedance.
2.  What do you mean by this?  I have a older 16 step TVC (-32db) that doesn't go low enough for my tastes, but the 24 step (-48db) is just fine.  I know Nic makes one that goes even lower to.
