Squeeze Box Power Supply
bhobba
Re: Squeeze Box Power Supply
« Reply #20 on: 27 Dec 2007, 11:55 pm »
Sure does.  I haven't even come up with a theory yet.  A bit more time maybe - but as yet - zilch.  It was a long shot anyway as the DAC has its own transformer.
I finally have a theory.  The negative impedance of Hologram at higher frequencies 'sinks' some the grunge that would have made it into the DAC in the form of jitter.  A test would be to see if the effect still occurred if the Squeezebox is clocked externally using for example a pacecar.  Best I can do at the moment.  Strange effect for sure.
Bill
