0 Members and 1 Guest are viewing this topic. Read 4961 times.
SteveWhat a treat! Premium pre knocking on the door of affordability! The SAS pre has long been on my Wanted List of possible tube preamps to own! I could not access your SAS Forum, without joining, to take a peek of the 7A! Best RegardsDennisPs. I read somewhere that you use Gregg's Reality cables for the internal wiring. Is this true?
Hey Steve are you still working on the phono pre or has that been put on a the back burner with the 7a release?
Hey Steve,Any updates on the 7A?Lin
Hi, I don't know if I will have a tour or not as there has already been alot of interest in the 7A. It will come with a 3 year warranty on parts and labor and 1 year on tubes. It has fallen behind schedule; maybe two weeks or so before completion and then breakin. I will decide in the coming weeks about a tour.I am thinking of a HT bypass option upon request. It will simply route any input directly to the output with a flip of the switch. One could then shut off the preamp when in HT use.Take care and thanks.Steve
"Hi Steve,Sounds mighty fine on the 7A. Why not just stick to the 2 volume controls? Seems like you'd be losing some openness this way. You'd still have the two controls. Is there any way of giving some idea subjectively the differences between the 7A 10A and the 11?Ray" Good question Ray. There has been such a call for the convenience of a single knob volume control, I thought I might go this route this time. I will offer the option of two volume controls as it won't cost anymore to build one or the other.I will also offer an optional bypass switch for HT. The 7A, although not quite, not quite as good as the 10A or 11A, still exhibits outstanding transparency, dynamics, tonal accuracy, soundstaging, and lifelike sound. I think one will be hard pressed to find another pre that will equal or beat it.All the best Ray and thanks for your input.Steve
"Hi Steve,Just curious, do you use tube rectification or SS? On the 7A, same question? any info on it, like tube complement features etc. output inpedance and all that good stuff?Ray"I use SS rectification although I do use a different power supply than most. I can detect no ringing or other abnormalities from the diodes in my designs. I use the JJE88cc, special caps on the 10A and 11A but a different arrangement on the 7A.Specifications:Frequency Response: 10 - 25 khz (+0, less than -.1db, 100pf, 100k load) Gain: 21db gain, approx. (can be set lower on individual inputs)Maximum Output Voltage: 9 vrms Total Harmonic Distortion at 2 vrms: 0.02% or less. (Predominate harmonic at least 74 db down.) Signal Polarity: Inverts Input Impedance: 25k ohms Min. Amplifier Input Impedance: 20k Volume Controls: 1Balance Control (approx 3db variation) Tape Loops: Special order:Line Inputs: 3 (additonal special order) Preamp.Outputs: 1 (but can add if ordered) Tube: JJ E88CC (Far superior to other E88cc/6dj8 types for low distortion.) Line Cord Length: 6 feet standard Power Consumption: approx. 8 watts Power Requirements: 120 Volts AC, 50/60hz. Cheers.Steve
Hi Ray, Maybe a little (not much mind you) soundstage and slightly less highs. Maybe not quite as refined. I think it is darn close between the two though.Another thing to ponder is that transformer based passives are more reactive than a well designed active preamp.
