0 Members and 1 Guest are viewing this topic. Read 10217 times.
The Sub One is a no compromise design. It uses twin extremely long throw 12" woofers in a push - pull configuration for quick, tight, accurate bass.The push - pull configuration allows for very deep bass (and a low Q response curve) in a relatively modest enclosure size. A manufacturer would have to build a cabinet twice as large to go as low without compound loading. Sub18" Sub One shown in Quilted Maple(Click on photo for a larger view.)A note on compound loading: the two drivers are mounted face to face, doubling the motor power. The inner woofer drives the enclosure, providing a neutral atmospheric pressure area between the drivers, so the outside driver can move instantly and effortlessly against little resistance. Most importantly, it provides quicker acceleration and braking for the outer driver. This allows it to start and stop instantly when the signal starts and stops, so there is no overshoot to muddy the sound. You will feel the difference.The woofer cabinet is a sealed design, so there is no "box echo", or resonant cavity effect coloring the music. The flatter low frequency response curve rolloff of the sealed design (12 dB slope per octave vs 24 dB rolloff for a ported design) closely matches the typical "room gain" at the rolloff frequency, therefore producing flat bass to below 20 Hz. in most rooms, without the inevitable coloration induced by ported or even servo designs. This design produces the most natural sounding bass possible. Non-downfiring.The Sub One comes in two sizes: 16" diameter x 36" tall, and 18" diameter x 26" tall. Both have the same internal volume, and the same response characteristics. You may choose the one that best fits your room decor and the sub location. We recommend using them in matched pairs.Sub Ones are available in beautiful wood veneers to match the satellites, or in solid colors.
Mike,Yes, it helps. How does the back wave of the inner driver dissipate?
Mike D,If volume was the limiting factor, would this get to the lowest frequency at a given volume?
The only purpose of the inner woofer is to reduce the back pressure on the outer woofer.Does this help??Mike
The Rythmik pictures does not display the Huff setup.There, one driver is inside an isobaric. The other driver is the "port", but they are still inside the cylinder, and it is not vented...It has "slots" that most likely equal a port in function and volume.Hey... I'm not a subwoofer designer.. so please correct me if I'm off here! I think I've read something a while ago that using a pair of the larger Ohm speakers as subs is suppose to be simply amazing?You'd have to have silly amounts of power I can imagine!!!Imperial
Quote from: Imperial on 5 Dec 2007, 12:47 amThe Rythmik pictures does not display the Huff setup.There, one driver is inside an isobaric. The other driver is the "port", but they are still inside the cylinder, and it is not vented...It has "slots" that most likely equal a port in function and volume.Hey... I'm not a subwoofer designer.. so please correct me if I'm off here! I think I've read something a while ago that using a pair of the larger Ohm speakers as subs is suppose to be simply amazing?You'd have to have silly amounts of power I can imagine!!!ImperialHere is a picture from the bottom of the page I pointed toI was referring to figure A), the Push Pull configuration.If the drivers are wired out of phase, then you have push pull. Both drivers will be either going in, or out at the same time (relative to the cabinet), but one will be moving forward while the other is moving backward.I am a little confused by Huff's page, because it says the drivers are facing each other. They don't show a picture of the driver mounting, so I am not sure how they do that and get push pull.Randy
But an even easier and more effective way to accomplish B (for sub use) is to mount the drivers face to face . . . . you eliminate one cabinet structure by doing this . . .
Quote from: Mike Dzurko on 5 Dec 2007, 02:02 amBut an even easier and more effective way to accomplish B (for sub use) is to mount the drivers face to face . . . . you eliminate one cabinet structure by doing this . . . Ok Mike, I am now more confused than usual.You know way, way more about this subject than I do, but I thought the animation from the link below shows push/pullhttp://www.avsforum.com/avs-vb/showthread.php?p=12398727#post12398727Randy
I can understand the compound loading more easily. The Huff states that their drivers face each other and there are being push/pulled. Am I to understand then that the Huff set up has air coming out it's rear end, so to speak? It's a compound farting machine?
