Basic receiver with dual-zones?
0 Members and 1 Guest are viewing this topic. Read 845 times.
Tim S
« on: 1 Dec 2007, 07:54 pm »
I am setting up a small distributed audio system in a house I am building. I'm going to have stereo speakers in two rooms with a squeezebox as my main source. I'm not so worried about sound fidelity for this so I would like to find a simple, cheap receiver that could possibly serve both zones without any extra amps. I was looking at the Panasonics as a possibility but it doesn't look like they would do the dual zone. Anyone know of good options for this?
Tim
Re: Basic receiver with dual-zones?
« Reply #1 on: 1 Dec 2007, 10:14 pm »
It sounds like you need a receiver with speakers A&B.  This would allow you to select room A or room B or both.  How much are you looking to spend?
Toka
« Reply #2 on: 1 Dec 2007, 10:57 pm »
Not sure what your budget is but the Outlaw RR2150 sounds like what you are looking for...can have speakers A, B, or A+B at once. That is probably you best option as far as new production equipment is concerned. Otherwise, there are a plethora of older receivers (Sansui, Yamaha, Pioneer) that would do that as well, but you will probably need to get it worked over/checked out.
Tim S
« Reply #3 on: 1 Dec 2007, 11:25 pm »
Ideally I'm not looking to spend much. <$500 would be great. I looked at the Outlaw, but it only has 2 amps which means that I need two more amps for the B speakers right?
Now that I state it clearly, I'm not sure this is a feature found on many receivers so I may have to go up in price unless someone know something I don't. . .and I'm hoping someone does.. .
Tim
John151
« Reply #4 on: 2 Dec 2007, 12:50 am »
Are you looking to play the same source in both rooms?  If so, then as previously suggested, a simple A+B will work, which most receiver have (possibly all).  However, if you want to play different sources in each room, then you need a multi-zone receiver, which is much more complicated and expensive.
I used to have a multi-zone A/V receiver in the family room, and used the second zone to power the patio speakers.  It was set up so that kids could watch a DVD inside, while the adults listened to music outside.  The set up was complicated, and never worked very well.  Once I got the SB3, I sent the digital output to the receiver for listening in the family room, and then sent the analog outputs to a simple integrated amp that I purchased used.  This set up works much better than the original multi-zone set up.
If you want to keep the costs down, then you could consider a used receiver.
Tim S
« Reply #5 on: 3 Dec 2007, 02:01 pm »
I don't really care that much about routing separate signals to each zone. For what I'm doing that shouldn't be necessary. I guess I'll have to go by Best Buy and actually take a look at some of their basic receivers to convince myself of how they work. I haven't really looked at that market in a while so I just don't know what they are capable of.
Thanks for the suggestions.
Tim
« Reply #6 on: 3 Dec 2007, 05:08 pm »
Tim routing the same signal to two sets of speakers is easy.  However, you need to consider the sensitivity and ohms of the two sets of speakers.  One set may play louder than the other.
Routing two different signals to two different sets of speakers requires either
1)  Two receivers, one with second zone or tape loops.
2)  One receiver that you can configure it's amps for second zone power.
If I were you I'd put up a WTB add with price range here and HTF for someones older HT receiver that has speakers A,B or A&B.  Many receivers can do this.
