0 Members and 1 Guest are viewing this topic. Read 3321 times.
What exactly is this, and what does it do?
Will you be having any future connection options for high level connections to sub (i.e., speaker lvel input) in addition to RCA?
Quote from: pwhartman on 30 Nov 2007, 08:05 pmWill you be having any future connection options for high level connections to sub (i.e., speaker lvel input) in addition to RCA?No... but PE sells some sort of adapter for such needs that should work.
Kevin,I'd like to ask a question or two about the suitability of using the WW on speakers that already have a low-pass filter for the woofer sections, specifically my VR4JRs which are crossed over at 200 hz. I hope this may be of interest to others too, it seems like such a cool little device:1) From another thread : "Adjustable Low-Pass Filter 12db/octave or 24db/octave with fully adjustable corner frequency" - How high is this corner frequency? Would I just set this corner well above the 200 hz, let the internal speaker low-pass do its job and then EQ as desired? Can it be used in this way w/ drivers that already have a crossover in front of them. Or could you bypass the internal crossover and just use the WW. (Hmmm, that sounds interesting...)
2) I'd want to use my tube amp (30.5 db gain, IIRC) on the mid/tweeter module and my CIA D200s (26 db) on the woofers. Is the 6 db gain that the WW provides enough to match the tube amp (I don't know if 26 db + "X" db is simply straight addition). Or am I better off getting the D200s bumped to 32 db gain and than use the WW to attenuate?
3) What are the DIP switches for? Hopefully you can call up one of several EQ programs in memory w/ the flip of a switch. Like, "OK, its quiet time, lemme call up the "bass boost" setting - It'd be so nice not to have to pull out the laptop for this. If not, can you store multiple settings in the laptop for quick retrieval?
4) Price - Obviously I'd need 2 WWs. I think many users might need a pair of these but would need only a single mic. Would you consider a price break on a pair , or maybe have a "stereo package" w/ one mic? Maybe? Please? C'mon I'm grovelling here...
Sorry if too many questions, but I think this is a really interesting product and I'm just wondering the best way to implement on my speakers, if possible.Thanks very much,-Mike
