New Amplifier Lineup
0 Members and 1 Guest are viewing this topic. Read 6973 times.
Kevin Haskins
Re: New Amplifier Lineup
« Reply #20 on: 30 Nov 2007, 04:29 pm »
Mr. Haskins,
This is one heck of a deal you're offering, I haven't seen anything this good in a long while. If you don't sell a ton of these, it'll only be because the word didn't get out to enough people or is this just a special for Audio Circle members?
Very attractive pricing on a high quality product.
Best Regards,
TerryO
This offer is only open to those who know the secret handshake, and who can identify the difference between a Super Klamodyne and a Bose 901 in blind testing.
klh
« Reply #21 on: 30 Nov 2007, 05:18 pm »
Kevin...
If I were you, I would also do two packages for IBers.
1. For those that have money to spend, Four Tempest-X's, one woofer widget and an FS1200TS (325 watts to each speaker given each sub is 4 Ohms and they are wired in series). Since most IBers have their drivers all co-located, only one widget is necessary. An 8 Ohm load is nice and easy... decreases wear on the amp and likely keeps it quieter. 325 watts to each speaker should also be just enough to get them close to excursion limits without going too far (plus you have the woofer widget for added protection)
2. For those with a bit of a budget, Two XJ-18's, one woofer widget and one FS500TS (500 watts each provided the subs are 4 Ohms each). In this case the woofer widget would pretty much be a must for protection.
I would also ask ThomasW at The Cult of the Infinitely Baffled if you can post your prices there. If so, I think you'd get a lot of sales. I would also mention that it can be coupled with a BFD if people want more PEQ channels as well as your 30 day money back guarantee on fan noise.
« Last Edit: 30 Nov 2007, 05:37 pm by klh »
Kevin Haskins
« Reply #22 on: 30 Nov 2007, 07:26 pm »
Kevin...
I will do some packages, there are limitations based upon how the shopping cart works.   It isn't able to do complex shipping calculations for multiple boxes so it causes me some grief when I do these packages.
The IB packages are a good idea though.  You don't need near as much power.   If you look at the price delta on the amplifiers, the only big jump is from the F250TS up to the F500TS.   After that, its hard to not just spring for the big-boy F1200TS and never have to worry about having enough power.   :drool:
