0 Members and 2 Guests are viewing this topic. Read 22735 times.
Yep, there it is... and it has been there since 2006? At least januar 2007.I have thought about an active bass system, but there is another issue present that remains fairly significant in my opinion. The input impedance for plate amps is terrible - about 10k ohms. This requires a very robust preamp that would add at least $1500 to any decent system. And the preamp would have to have output cables for the plate amp. I tried an okay quality (Tweaked Foreplay) preamp several years ago and ran the cables through the plate amp and used the high-pass for the monitors. It completely ruined the midrange quality. It became very gritty and grainy - with no dynamics.I really don't think there is a clear "winner" in this situation - unless there is a high quality plate amplifier with a high input impedance and very high quality active crossover circuit for the high-pass. This would necessitate mono-block amps, or more RCA cable, but this is a minor concern in the grand scheme of things. Do you know of a plate amp having at least 50k ohms of input impedance AND some degree of quality discrete components (i.e. no op amps) for a high pass? I use my sub without high passing the monitors, no need for me; but I do understand your wish in this matter (reducing the VC/cone displacement and therefore related distortions...IMHO overstated distortion type on 99% of the music types and in domestic environment). My Callisto1 from Sitronik Industrie has an input impedance of 47Kohms on the line input but I own an SKA integated amp without preamp for the monitors , thus I use the high power input of the Callisto (300 ohms) running cables to the speakers output of the SKA:http://www.sitronik-industrie.de/frontend/dyn,pmode/eshop/shop.php?rub=h7&sub=subbooster&shopy=692cebdcca03e6be30dd37d7c904ffd5
