Bugle Caps
0 Members and 1 Guest are viewing this topic. Read 1476 times.
PatOMalley
  • This text is personal
    • http://home.comcast.net/~omaille/audio/home.html
Bugle Caps
« on: 25 Nov 2007, 02:14 am »
Which caps are in the RIAA?
C1, C3, C4, C6.
C11, C8
What I was thinking was to change the output/coupling caps. Are these C1 and C4?
I now have Auricaps in C1, C3, C4, C6 and would like to swap the coupling caps for Mojotone Vitamin T (Oil filled). Can I just swap out the coupling caps or should I replace all: C1, C3, C4, C6?
hagtech
Re: Bugle Caps
« Reply #1 on: 25 Nov 2007, 07:17 pm »
The BUGLE has no output caps.  That is part of the beauty of the design.  Instead I remove most of the dc offset with a coupling cap C1 to the final gain stage.  This means the cap does not have to deal with external influences (like a cable).
All of the caps are part of the RIAA EQ.
jh
