0 Members and 1 Guest are viewing this topic. Read 6239 times.
What I'd really love to do is a Unity Horn but Tom Danley isn't interested in sharing.
speaking of the old HE 10.1's,,,,I have a pair that Ive never used with anything but some old Norh le amps. I only bought cause they were used and cheap (under a $100).Got an amp recomendation that will make these sing?
Quote from: Kevin Haskins on 20 Nov 2007, 04:24 pmWhat I'd really love to do is a Unity Horn but Tom Danley isn't interested in sharing. I suspect Tom is still smarting from the last diy-ish episode.Someone has posted an Akabak script to diyaudio that models the Unity. Might be worth a look - if you can back into determining the right parameters for the mids, you'd already be ahead of the game. Coming to the table with a design that works might help the discussion surrounding licensing.Conversely, I still think the idea of a Yorkville U15 massaged for home use would find some takers. I'm using these at home, and find them great. I'm not sure the volume you might be looking at would be enough to support any official partnership, but it may be worth mulling over.
On a realted note Dan Wiggins offered an update to this design....slightly different Tweeter& of course XO. Has anyone heard this or know of the differences?
thanks Kevin,,,I'd be very interested
