Simple DEQX question....?
fu_man
« on: 16 Nov 2007, 06:07 am »
DEQX  requires  a a  separate amp  for  each driver... does this mean I need mono blocks , or  can I use a  stereo  amp for the mids ,  stereo  amp for  twin subs  etc?
(sorry...   i know this  sounds  like a  dumb  question  that I should have  been  able to figure out for myself!)
playntheblues
  • D-Sonic, Mola Mola TamBagui, Tekton DISE
Re: Simple DEQX question....?
« Reply #1 on: 16 Nov 2007, 11:16 am »
Stereo amps will work fine.   :thumb:
JoshK
« Reply #2 on: 16 Nov 2007, 02:12 pm »
You can even use a 6 channel amp, or two 3 channel amps, or 1 4 channel amp plus a stereo amp....you get the picture.  :wink:
doug s.
  • makin' music
« Reply #3 on: 16 Nov 2007, 07:08 pm »
one more thing - if you have, say, a three-way speaker, & it's only single-wire capable, you will only need one stereo amp, & the deqx will still work w/it.  you yust won't be using its x-over capability, only its eq capability will be used.
doug s.
fu_man
« Reply #4 on: 19 Nov 2007, 11:51 am »
okay...cleared that up.  Thank you guys... I shall continue my  search for that elusive  secondhand  unit which  someone is willing to ship (back) to the  other  side  of the world!   :)
