BuglePro mono switch
0 Members and 1 Guest are viewing this topic. Read 1163 times.
Clive
« on: 14 Nov 2007, 08:49 pm »
I've seen an interesting mono switch arrangement elsewhere that might be of interest to BuglePro users.  There are 2 push button switches, one to derive mono from the right channel, the other switch uses the left channel.  This allows you to chose the quieter side of the groove for your music.  Using both switches mixes mono from both channels.
« Last Edit: 18 Nov 2007, 12:43 pm by Clive »
PatOMalley
  • This text is personal
    • http://home.comcast.net/~omaille/audio/home.html
Re: BuglePro mono switch
« Reply #1 on: 17 Nov 2007, 01:41 pm »
I disconnected my mono when I was troubleshooting noise issues. This looks like a great way back. What is the part #?
Clive
« Reply #2 on: 18 Nov 2007, 12:45 pm »
No part number....I've only seen this on a similar unit to the Bugle Pro, it was implemented with 2 push buttons.  You could use 2 toggles, the same type as you have for the mono switch now.  The "similar" unit was really expensive.....
