50" Plasma HDTVs
0 Members and 1 Guest are viewing this topic. Read 5325 times.
kmmd
    • Systems
Re: 50" Plasma HDTVs
« Reply #20 on: 11 Nov 2007, 10:05 pm »
The Pioneer PDP-5010FD ($3450) will run you about a cool grand over the excellent Pioneer "Kuro" PDP-5080HD ($2450).
Either is a great choice.
George
I agree that both are excellent.  However the PDP-5010FD and PRO-110FD are 1080p.  The 50-inch PDP-5080HD and Elite PRO-1150HD are 1365 x 768.  They look fantastic also.
Ken
PaulFolbrecht
« Reply #21 on: 11 Nov 2007, 10:59 pm »
I've been looking at the Pioneer PDP-6010FD - decided I can do a 60" if I move it up a bit, as suggested.
About $4100 delivered from the best eBay power seller.
PaulFolbrecht
« Reply #22 on: 17 Nov 2007, 05:21 pm »
Any opinions on the LG 60PY3D?  Almost $1000 cheaper than the Pioneer, and some prefer the picture.  True 1920x1080p.
PaulFolbrecht
« Reply #23 on: 18 Nov 2007, 11:10 pm »
The wife & I stopped at BB this evening to check out the TVs.  Short story shorter, the Pioneer is the best by a good margin.  Their 60" plasma looked better than the Panasonic and the LG.
Questioned settled.
