FS/FT: PAudio 12" coax drivers and 3 way switches for high freq. Spec's added/
0 Members and 1 Guest are viewing this topic. Read 1918 times.
Whitese
Price 350 bucks for drivers, switches and caps. plus 1/2 shipping
I had these in TL cabs and they are simply tremendous!! great bass, and clear clean highs and great mids, that only a paper cone can give you.
i kinda dont wanna sell, but I need money for some gear repair.....(bloody hell vinatge crap..:-))
they are in excellent shape, except one driver has one of the springs on the the binding posts went kaput in shipping...I just wire it tight or you can solder it...I have ran it with  no problems whatsoever.
I sincerely believe that they rival Tannoys and better them in tightness/clarity etc..
PIc of the three way switch:
you can see the broken push pin.
I will include a 3 way switch and caps that I bought from PAudio to tailor the high freq roll-off...never used.
« Last Edit: 9 Nov 2007, 01:45 pm by Whitese »
bikes and beats
What do you want fer 'em?
Whitese
350 and split shipping...price is in bold at the top of the ad. :o
Whitese
JoshK
Just a suggestion that you might want to list where you are shipping them from.
If I wasn't buried in projects and low on cash I might bite.  They have always intrigued me.  Good luck with the sale, I am sure a buyer will be happy.
Whitese
thanks JoshK..your always busy building stuff..! :)
they are being shipped from Douglas, GA 31535....I have the original boxes///
OR also, partial trade for a McIntosh C32 preamp?
Whitese
It seems to me that its more of an OB driver.
specs:
Some specs:
Power capacity (RMS) : 200-400 W
Sensitivity: 100 dB
Resonant Freq: 55 Hz
Impedance Re : 5.6 ohms
Electromagnetic Q Qes: 0.43
Mechanical Q Qms: 8.19
Compliance equiv volume VAS : 103.54
BL :15.91
Voice Coil diameter: 2.5"
VC material: edge wound copper clad aluminum wire
Gross weight: 18 lbs
HF unit:
power capacity 30-60 continuous prog
sensitivity: 106dB
Freq range: 1.5Khz to 18 Khz.
VC diameter: 1.75"
diaphragm material :titanium
dispersion pattern : 80 degrees
Whitese
Thanksgiving reduction!!
300.00 dollars and split shipping!!
