0 Members and 1 Guest are viewing this topic. Read 5642 times.
Hi Terry,Do you know if the improvements or enhancements made to the K2 CDs will be as evident if the material is copied onto a HDD for computer-based playback?Thanks.
Can one actually order any of the K2 recordings shown on the page, or is there a more extensive catalog somewhere? The FIM catalog search turns up no matches, despite the listings on the news page.It would be nice to see an improved format take off, but the price needs to be right, and the studios need to reign in the DRM.
K2 discs can be ordered from Acoustic Sounds.http://store.acousticsounds.com/category.cfm?id=185
Members of the Pacific Northwest Audio Society recently got to hear some of the new K2 format CDs.
Inserting an A/D/A convertor in the chain is not the same as playing a redbook CD. Without having seen the actual paper, it seems that the true result would more likely be that the bandwidth limit and quantization noise of a 16-bit 44.1 kHz signal were not sufficient to enable listeners to statistically distinguish between a signal with and a signal without.I think a more interesting test might be to digitally alter a high-rate 24-bit signal, and determine at what point listeners *are* able to distinguish the altered signal from the original.
The whole thing just sounds like a fancy dithering.
You cannot compare SACD or DVD-A to the same release's redbook version because the studio's make them different to scam the consumer into thinking HD formats are necessary rather than just using the same data and filtering it to 44.1khz and then dithering to 16 bits so that both recordings are identical except for noise floor and bandwidth.
I found the K2 system on the JVC site with an explaination.http://www.jvc-victor.co.jp/english/products/others/digitalk2-e.htmlIt literally does nothing and is a scam.
How exactly do you know this to be true? It seems to me a given studio could use whatever process they felt like without your knowing about it. Is every studio in the world in on this "scam"?
Now if the CD layer on a hybrid SACD is mastered differently, that would be a scam.
Its annoying having to use a HDMI to DVI + SPDIF breakout box to capture the SACD layer digitally to add to my music server.
Here is a simple argument for at least a 24bit recording and replay system. See link below. CD dynamic range: 96dBhttp://www.cutestudio.net/data/products/audio/CD%20clipping/index.phpThe question is what percentage THD is equivalent to -50 to -60 below Zero dB in a 16bit system versus a 24 bit system. In a digital recording system distortion rises as the signal amplitude decreases. It would be nice if if the lowest level signals didn't have more than 3% THD in a high resolution system. Scotty
