GK-1 Picture......
Pleb Plebian
GK-1 Picture......
« Reply #20 on: 14 Jan 2003, 02:46 am »
Hi Rocket;
Propstuff is (mostly ;-) right - the difference is that SS can be polished to the point it has a better finish than Chrome...and you'll have a very hard time getting chrome to stick to SS.
Talk to the guys doing the cutting, see if they can recommend a good sheet metal polishing shop...then take the cut bits in and get a quote on bringing the parts polished to a "BA" (Bright Annealed - shiny SS finish.....but easily used as a standard) finish.
We'd charge about 30-40 mins to do a job like this...so check their chargeout rates and compare it against the quote :-)
Other possibility is Electropolishing - this however tends to be a bit more specialised.
Hope this helps - SS _does_ give an awesome finish!!
-Pleb (Darl)
