Strat Mini vs ACI Sapphire XLs
0 Members and 1 Guest are viewing this topic. Read 6010 times.
raztec
« on: 31 Oct 2007, 04:41 pm »
I've got my media room finished and am building a home theatre system from scratch. It's 22' x 11' with short 6'5" ceilings and I listen to 50-50 music-cinema.
I've narrowed my choice of receivers down to the Arcam AVR300 vs. Rotel RSP-1069 and speakers between the Strata Mini vs. ACI Sapphire XLs + sub.
Does anyone have any recommendations between these components and which receiver would best match which speaker? I like to listen to music fairly loud but don't want a fatiguing sound either.
Thanks a bunch,
Raz
« Last Edit: 2 Nov 2007, 08:22 am by raztec »
ajayrav
Re: Strat Mini vs ACI Sapphire XLs
« Reply #1 on: 31 Oct 2007, 04:48 pm »
I use the Arcam AVR300 with the Sapphire XLs and really like the combo.  My sub is an Adire Audio Rava and I have the crossover set at 60 Hz.  Front end is a Marantz SA8260 routed through a Musical Fidelity upsampling DAC and tube buffer.  Sounds great to me.....
Ajay
Bob Reynolds
« Reply #2 on: 31 Oct 2007, 04:54 pm »
Since you haven't committed to anything yet, how about the NAD pre/pro with Audyssey room correction and active speakers (Mackie, Genelec, ATC, JBL, Dynaudio, Blue Sky)?
  • Speakers....What Speakers ?
« Reply #3 on: 31 Oct 2007, 05:10 pm »
I'd go for the ACI Sapphire XLs + sub.....you can listen all day (and night)....its a very good speaker. :wink:
Zero
« Reply #4 on: 31 Oct 2007, 05:13 pm »
Ditto to the above.
raztec
« Reply #5 on: 31 Oct 2007, 05:36 pm »
Though I've heard OF active speakers, I've never actually heard them to determine how much better they are in real life and to my moderately discerning ear.
I haven't looked into this setup but may. Will the whole system set me back more than $5000?, my budget.
Raz
raztec
« Reply #6 on: 31 Oct 2007, 05:42 pm »
After doing the math, it's no wonder, the Xls sound better. I think these speakers must be in a different category all together.
Strata Mini + Center channel = $1700
Sapphire XL + center channel + stands + sub = $3500
sts9fan
« Reply #7 on: 31 Oct 2007, 05:44 pm »
what center for the strata? I don't think you will get a new pair of mini's + a center for $1700
Hoots
« Reply #8 on: 31 Oct 2007, 05:48 pm »
From what I've heard of the Mini I would say the same thing...it didn't seem fatiguing at all and it's a very good speaker with  "Planar Magnetic / Cone hybrid & Powered 8" woofer" design--"a taste of the high-end at a fraction of the price".
I listened to femail vocals like Diana Krall, Kate Bush, Cat Power, Laurie Anderson, etc.  I was listening for smooth non-fatiguing sound.  I didn't play any 90db+ Black Sabbath, etc. but with the music I heard I dialed down the powered woofer.
Zero
« Reply #9 on: 31 Oct 2007, 05:48 pm »
It also may be a stretch to assert that the Mini can fill such a large space by itself.  According to MLS, this speaker was designed for 'intimate' (read: close quarters) stereo listening.
« Reply #10 on: 31 Oct 2007, 05:50 pm »
I don't deal with math....just sound quality. As for math....its not always that the most expensive is better. :thumb:
bpape
    • Sensible Sound Solutions
« Reply #11 on: 31 Oct 2007, 05:50 pm »
I listened to femail vocals like Diana Krall, Kate Bush, Cat Power, Laurie Anderson, etc.  I was listening for smooth non-fatiguing sound.  I didn't play and 90db+ Black Sabbath, etc.
I think Wolfy was referring to the Sapphire when he made the statement about being easy to listen to - not the mini.
Bryan
« Reply #12 on: 31 Oct 2007, 05:55 pm »
Bryan
Correct..... :thumb:
And the Sapphire's sound very good loud....I still remember....the Tubes - "White Punks On Dope"...... :dance:
Hoots
« Reply #13 on: 31 Oct 2007, 06:02 pm »
Bryan
I know...the point is I think you can make the same non fatiguing & not harsh comment about both.   I also don't think 22 x 11 with 6.5" ceilings is very big.  While the Mini was designed for stereo it seems the HT results have been a surprise using the REF 100 center.   I think my biggest question would be around big dynamic movie events--or maybe getting that live arena-like hard rock sound (vs a big tower).
raztec
« Reply #14 on: 31 Oct 2007, 06:05 pm »
Check out the link below on the specials AV123 has going: Strata Mini $1299 when bought with Ref 100 Center $349
http://www.av123.com/products_product.php?section=speakers&product=78.1
ajayrav
« Reply #15 on: 31 Oct 2007, 06:32 pm »
I don't know how good of a match the Ref 100 center is for the Minis.  MLS has stated on the AV123 forum that they are working on a matching center and surrounds for the Minis, but this is still in the design stages.  Maybe they will allow you to upgrade to the new Center when it becomes available.  I would advise you to audition both and then see what your budget permits.  Both MLS and Mike D sell great products, so its a win-win situation for you!
Ajay
emac
« Reply #16 on: 31 Oct 2007, 06:59 pm »
I've heard the Sapphires w/ a sub and I currently own the Mini's.  Absolutely love the Mini's.  Such a wondefully intimate listening experience.  Will do just fine in a room that's 22x11, which is roughly the same as mine.  If you really want to crack 100+ dB, then they might not be the best, but for most listening, they do a fantastic job.
For me at least, the Sapphires aren't much of a match for the Mini's.  They were very precise, but almost too much so.  Not my cup of tea.
Bob Reynolds
« Reply #17 on: 31 Oct 2007, 10:28 pm »
Raz
When you consider that you get a true biamped system in a 2-way speaker, active speakers are an excellent value.
You might want to peruse some pricing here: http://www.bhphotovideo.com/c/shop/1641/Active_Monitors.html
For example, the Blue Sky SAT 5 MKII is $400 each, which includes a pair of 60 watt amps. The SAT 6.5 MKII is $600 each, which includes a pair of 100 watt amps.
The three brands I would consider reasonably priced are: Blue Sky, JBL and Mackie. Note that the JBL LSR4300 series has room correction builtin - the speakers are all networked together. So an Outlaw pre/pro would be a good match with them.
One possibility would be a trio of JBL LSR4328s across the front, a pair of JBL LSR4326 for the rears and the JBL LSR4312 sub. Total cost is: $3687. The Outlaw Model 990 pre/pro is $800. Go to Blue Jeans cable for all your cabling and you will have a very nice system within a very reasonable budget.
Mike Dzurko
« Reply #18 on: 31 Oct 2007, 11:47 pm »
Thanks all, I'm sticking my nose in here so I can get auto notification and follow this most interesting thread.   8)
If I can be of assistance, do let me know.
satfrat
« Reply #19 on: 1 Nov 2007, 12:53 am »
Scan-Speak cones has 1 of the most sweetest midrange drivers out there and even tho I've never heard the Sapphires, I have Scan-Speak drivers in my Lorelei's and they are truely captivating. That and the fact I trust Lonewolf who has heard them makes for an easy choice to me.
Oh yeah, I do have the Force XL and you won't be disappointed when you start feeling the vibrations in those bass ladened movies.  :D Are you planning on rear speakers or are going to just half step your home theater?  :o A center channel speaker is a must have item for correct direction and motion of the sound. Now it's no biggie if the center's different from your mains but today, there's a lot of Dolby Digital and DTS concerts available, my DirecTv HD has concerts in Dolby Digital each and every weekend and to properly enjoy this, ideally you'd have 5/6/7 speakers that were all the same. Anyways, I'd recommend that if you don't plan on rears (big mistake), I would try and get Mike to sell you 3 Sapphires for your front line speakers. You'll have correct tonal balance and even tho isn't not necessary for movies, it's a must for music. Even if you're only a 2-channel music fan, you'd be shorting yourself bigtime for those music shows in true digital surround, aka 5.1/6.1/7.1 with each speaker having it's own true individual sound. 2-channel doesn't cut it when you're talking about home theater DTS/Dolby Digital recorded music.
Something to think about and I know what I'm talking about from experience with my own home theater system. Ideally, 3 sets of Sapphires and Force XL for a mind blowing 6.1 system. With a good 6.1 Dolby Pro Logic 2x (that's coded surround, unlike Dolby Digital), it'll rival 2 channel head to head. That's TOTALLY the bias in me talking so YMMV.  aa
Good luck with your decision.  :thumb:
Robin
