Torus - Feedback/Reviews
0 Members and 1 Guest are viewing this topic. Read 68104 times.
drummermitchell
Re: Torus - Feedback/Reviews
« Reply #100 on: 12 Apr 2009, 07:01 pm »
Your asking me :o :lol:.
Moon Doggy
« Reply #101 on: 13 Apr 2009, 12:01 am »
It will be a  very fast in and out kinda operation.... no questions asked....
Am i a bad husband?  :scratch:
With the improvement in sound from the Torus even the wife could notice.  :o  My  son who rarely hears the difference an expensive upgrade makes to the sound immediately noticed the improvement with the Torus I demoed.
werd
« Reply #102 on: 19 Apr 2009, 02:59 pm »
Hi James
I was wandering if the 120 volt can be easily converted to the 240 volt at a later date? If i buy a single phase am i able to easily change to dual phase (can it even be done) ? I really want one of these but i kinda stuck in the mud as to what i need/want.
drummermitchell
« Reply #103 on: 19 Apr 2009, 03:11 pm »
I'd do dual phase,because YOU  WANT ONE,and there's not a big price difference.
I bet 300-400 dollars an electrician could fix you up with materials+labour,( batteries not inc :lol:)..
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #104 on: 19 Apr 2009, 04:34 pm »
Hi James
Hi werd,
NO the 240 and the 120 volt Torus units use completely different transformers.
james
Phil A
« Reply #105 on: 19 Apr 2009, 04:48 pm »
It probably depends on where the electrical box is in relation to the receptacle.  When the house was going up (12 yrs. ago) I had them put a single receptacle on its own circuit in addition to what was on the wall where the system was going.  They did use a 20 amp breaker but just 14 gauge wire (I didn't specify - obviously I would do it differently today).  I finished the basement about 4 years back (have another system down there) and where the wall is to the main room upstairs it is now finished basement.  It would probably cost me more than 300-400 dollars to have someone rip up and repair what is finished just to have the electrical work done.
 I just ordered a 20 amp Torus last week (I'll use my other power conditioners in the bedroom and basement systems).  It will be fine for my 14BSST, my SP 1.7, and source components (e.g. BCD-1, Blu-Ray player) as they will only be one one at a time.  If I had done things differently, I would have at least put another receptacle on its own circuit.  I'll suffer with the 6BSST (used on the center and surrounds) and my 4 main system subs plugged into the wall.  If I had things to do all over, I probably would only have a 2-channel main system and I would have done the basement in a different configuration.
In my old house, I had a duplex receptacle on its own circuit but it was much easier as the main system wall where the receptacle had the garage where the electrical box was located.  Adding additional electrical stuff in that situation was much easier.  Ripping up the unfinished sheetrock in the garage and repairing it would be really easy in that scenaio.  Before I finished the basement I ran component and video cables from one side of the main room (now buried in the basement ceiling) to the other and chopped up a column behind to the listening chair to get the cabling up high for the projector.  Took me a mild bit of creative thinking to hide the long HDMI cable I ran last summer for the new projector.  While I don't plan to move again, if I ever do, I'll try to do a better job of leaving more options open.
werd
« Reply #106 on: 20 Apr 2009, 03:14 pm »
Hello James
I was wandering if you can tell me what gauge (10 OR 14) power cord comes with the torus rm-20. Both in single and dual ..... thankyou
« Reply #107 on: 20 Apr 2009, 08:21 pm »
Hello James
Hi,
The power cord for RM 20 is 12 gauge
james
werd
« Reply #108 on: 21 Apr 2009, 02:18 am »
Hello James
Hi,
james
Thanx james.... sorry i just found that info on the website.
werd
« Reply #109 on: 22 Apr 2009, 05:51 pm »
Hello everybody
James what is the wait time right for a dual phase rm-20? Trying to coordinate my affairs here and knowing this would be helpful.
« Reply #110 on: 22 Apr 2009, 05:58 pm »
Hello everybody
Hi Werd,
About 3-4 weeks from order.
james
drummermitchell
« Reply #111 on: 22 Apr 2009, 06:12 pm »
Werd,That's only 2 paydays,see very quick :lol:..
werd
« Reply #112 on: 22 Apr 2009, 06:17 pm »
yah my guy isnt there today, i have to wait till tomorrow to order it i guess. They want 2% now on these 3months no interest or payments deal.
werd
« Reply #113 on: 2 May 2009, 03:04 am »
Hey PhilA
I just ordered a rm-20 bal. also. I am just wandering how long you have been waitin for yours now? I am making sure i am putting 10 gauge in, any other things you might do diff if you had the chance with the 240 volt install?
Thanx
Phil A
« Reply #114 on: 2 May 2009, 10:35 am »
I've just ordered the RM20.  Not the RM20 balanced.  I have a receptacle on its own circuit I had put in when the house went up 12 years ago but I've since finished the basement and the main room is above it.  I'm not about to start ripping up finished stuff to run additional wiring and have to deal with the mess.  I think I have every circuit used on the 200 amp service already.  I had to compromise on the electrical stuff I did in the basement.  I didn't want to change the service for the secondary basement system that does not get used that often.  I'd also have to change the service if I wanted an additional circuit in the main room and that's probably $2k (so it would be close to $2.5k for the service and repairs if I went with an RM20 bal) . It's probably over 2 weeks since I ordered the RM20.  I'm hoping to see it in a week or so.
werd
« Reply #115 on: 13 May 2009, 08:43 pm »
Woot!! my rm-20 is in!!!! Now if i can figure out how to pick it up  :scratch:  :lol:
drummermitchell
« Reply #116 on: 13 May 2009, 10:58 pm »
Congratulations :beer:.what do you mean by pick it up(lift it or pick it up from the audio store.
If it's the first they are nasty for weight.
werd
« Reply #117 on: 14 May 2009, 01:19 am »
Both.... i hope the box will fit in the trunk of my 98 bonneville.  :)
Phil A
« Reply #118 on: 14 May 2009, 01:35 am »
I got mine Monday.  The box is about 21x23 inches and about 10 inches high.
werd
« Reply #119 on: 14 May 2009, 01:58 am »
Hi PhilA
Oh nice.... you just got yours too. How's it sound, does it need breaking in?
Might plug a 1000watt heater into it just break it in. Dont know if that is a waste of money or not.....
Thanx for the dimensions. I guess that will fit into my trunk comfortably.
