PCM1704 vs PCM1704U-K
0 Members and 1 Guest are viewing this topic. Read 1803 times.
Orson Garnsey
« on: 28 Oct 2007, 03:28 am »
I have a professionally modded DAC60 that PCM1704s as opposed to 1704U-Ks. From my research, I see that the "K" has better THD and dynamic range (102dB vs 106dB). Should I be concerned? Are these small differences likely to be audible?
Thanks.
*Scotty*
Re: PCM1704 vs PCM1704U-K
« Reply #1 on: 28 Oct 2007, 04:22 am »
Orson, You might ask why your DAC60 does not have the PCM1704U-K as it is specified to have on the Pacific Valve website. I wouldn't loose to much sleep over it, but you supposedly paid for the higher speced component.
Scotty
